All Activity
This stream auto-updates
- Today
Hi As per the title, does anyone have a rod that connects the driver side door handle to the mechanism? Not the one from the lock to the mechanism. I have several Mk4/5 ones, but they are longer. Thanks p.s. it looks like mk2 Escort are the same as mk3 tina - can anyone verify? However Escort stuff is subject to Escort tax (and therefore stupidly priced).
Hi Tim Ive been selling cars off over last few years only got half of what we did have Still got these two Mk1’s KPU all done and running great, ive been using it a lot and enjoying it
Thank you, but thats the problem, its a 82 GL but there are alot of things that are different from standard. I bought DTM470Y from the brother of Martin who was very involved in the cortina scene. I think he up specked alot of things, it 100% didn't have intermittent wiper as i often said to the wife I would prefer that, and if I flicked down the stalk the wipers went once than turn off and the stalk would sit in the original position. I have bought two off ebay that look the same but are not, so I think I should wait until the one Martin fitted, there must be one out there somewhere.
If this is your original switch then either of the 2 below on eBay are the same ,as pins match their lower spec MK4/MK2 escort. The V0 number is just the casting number of the mounting bracket. 366454764565 237044389833 An 82 GL would definitely have intermittent wipe & be the one in my pic.
- Yesterday
That's very expensive. Look for a lower speck MK4 one.
I think i have found one on line but the price is very high, hopefully I will see a second hand one.
Hi Rob, you must have enough LC's now to set up your own museum. Keeping yourself busy too.
Ford Sweden Works mk2 LC rally car resto
sheffieldcortinacentre replied to MLI's topic in Members' Cars
Stuff like this is fascinating. -
Right pic enclosed of the std Mk5 intermittent stalk ( commonist fitted) can't find a flick wipe one.
Ive had the Ove Andersson car around 5 years here in UK
Just busy doing other things and trying to find best way to get it back to UK A pal of mine in Sweden collected the car 2 years ago and it was stored at his place i did bring it back last week with 2 other Cortina’s Not easy getting non running cars back from Sweden now ? Very expensive ?
Why did it take so long to get the cars back to the UK ?
Flick wipe the lever would spring back up when released, intermittent would lock when pushed down & wiper would sweep once every few seconds till switched back up.
Typo
Although it is not a crusader, she is a 2lt GL, I cant remember it having intermittent wipe but if i did flick it down the wipers would work just the once, is that what you mean by flick wipe? Thank you for looking
- Last week
Might have one let me check. There's only 2 types fitted to mk5s intermittent wipe or crusaders had flick wipe. Do you know which yours was? Mk3s & low spec mk4s only had 2 speed wipers .
Both cars competed in 1000 Lakes Rally August 1967 Car numbers 36 & 35
Rob started following Ford Sweden Works mk2 LC rally car resto
Both cars are so original and correct 030 still has its fuel injection system
This car is now in UK and sits next to its sister car BA91GL91031 I purchased this car in Norway 2 years ago and have only just got it back to UK Both these Boreham Rally cars are back together sitting side by side after many many years apart Both cars are due to be restored 030 is Bengt Soderstom 031 Ove Andersson
joemayhook started following Mk5 wiper/lights stalk
Hi, i have a love 82 mk5 estate, only problem is the headlight stalk has just fallen to bits. I have bought to replacements but both are wrong, for older cars i think. im looking for part v032031 any help would be great. Cheers all Joe
Paulth70 joined the community
Drew joined the community
I possibly might be thinking of a change so my mk5 might be up for sale.....let me know if it's of interest, the link below has many pictures over the years. Car is presentable but definitely not mint although interior is excellent and drives very well. BuySellCortina - The Ford Cortina Forum
Speedbird350 joined the community
chimpteaser started following Is this Mk3 still a 1300?
This Mk3 came up in a google image search, it looks like it has escort bubble arches and a bit of a 70's jacked up look. DVLA says PRR418M is still a 1300? I can't find out much about it on't interwebs. Anybody have more info? PS. Great to see Bortaf back!
anglia struts
Newsletter
