FKLGLS 43 Posted July 26, 2007 Hi folks. Does anyone out there know if the backplate off an 1800 cvh sierra will fit the back of a 1600mk5 cortina and if so, will the starter holes line up with a 1600 sierra 5 speed gearbox ? Many thanks. Quote Share this post Link to post Share on other sites
apjoe18 0 Posted July 26, 2007 Hi folks. Does anyone out there know if the backplate off an 1800 cvh sierra will fit the back of a 1600mk5 cortina and if so, will the starter holes line up with a 1600 sierra 5 speed gearbox ? Many thanks. i dont know if it will fit but it might be easier to source a pinto sierra bell housing. i take it your converting to a 5speed box? Quote Share this post Link to post Share on other sites
FKLGLS 43 Posted July 26, 2007 Hi folks. Does anyone out there know if the backplate off an 1800 cvh sierra will fit the back of a 1600mk5 cortina and if so, will the starter holes line up with a 1600 sierra 5 speed gearbox ? Many thanks. i dont know if it will fit but it might be easier to source a pinto sierra bell housing. i take it your converting to a 5speed box? I am. I have the old bellhousing from the original 4 speed 1600 box. Would this mate to the sierra box ? If so, I could use the original backplate. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted July 26, 2007 all 4 cyl petrol type 9 5 speeds use the same bellhouseing & will bolt to a crossflow or ohc.. most back plts have long sinse been bined don't worry about it. Quote Share this post Link to post Share on other sites
apjoe18 0 Posted July 27, 2007 Hi folks. Does anyone out there know if the backplate off an 1800 cvh sierra will fit the back of a 1600mk5 cortina and if so, will the starter holes line up with a 1600 sierra 5 speed gearbox ? Many thanks. i dont know if it will fit but it might be easier to source a pinto sierra bell housing. i take it your converting to a 5speed box? I am. I have the old bellhousing from the original 4 speed 1600 box. Would this mate to the sierra box ? If so, I could use the original backplate. it may do as im sure the 5speed box was derrived from the 4speed case just made a little bigger, when i converted mine i just used the sierra bellhousing that came with the box. bolted straigt on. i wouldnt bother changing the backplate much easier to get a bellhousing i wouldve thought. Quote Share this post Link to post Share on other sites
bortaf 83 Posted July 27, 2007 5 speed plate needs to go with a 5 speed boxe as the starter is slightly lower on the 5 speed so a 4 speed plate wont line up round the starter hole! (found that one the hard way, after all the starter is the last bit you put back isn't it) :cheers: :oops: doesn't matter if it's cvh Quote Share this post Link to post Share on other sites
FKLGLS 43 Posted July 27, 2007 5 speed plate needs to go with a 5 speed boxe as the starter is slightly lower on the 5 speed so a 4 speed plate wont line up round the starter hole! (found that one the hard way, after all the starter is the last bit you put back isn't it) :cheers: :oops: doesn't matter if it's cvh Thanks Bortaf. I can get hold of a cvh plate to complete the job. However, I too have found out the hard way as the car is all back together, with the exception of the starter motor, which, er, won't fit....... Quote Share this post Link to post Share on other sites
bortaf 83 Posted July 27, 2007 Hardest lessons are the best learnt ones i find ( unfortunatly) :cheers: i know exactly how you feel mate :car: you could just cut the plate where the starter goes and use 3 washers to space it back again, save all the agro and get a plate later on :winner: Quote Share this post Link to post Share on other sites
apjoe18 0 Posted July 28, 2007 Hardest lessons are the best learnt ones i find ( unfortunatly) :unsure: i know exactly how you feel mate :cheers: you could just cut the plate where the starter goes and use 3 washers to space it back again, save all the agro and get a plate later on :argue: thats what i did on mine although it took some cutting as i did it with the box attached! what a job that was! Quote Share this post Link to post Share on other sites
