Sarkie83 0 Posted March 30, 2008 If you wanted to re-spray a car that was red/blue, white - are they any problems doing it? Are you going to have go down to bare metal to properly cover the original colour? Quote Share this post Link to post Share on other sites
forkliftfred 0 Posted March 30, 2008 Primer the whole thing first! Quote Share this post Link to post Share on other sites
richard 2509 0 Posted April 1, 2008 depends what state the original paint is in and if it is lacquered or in 2k...if its sound you dont need to prime over it just flat it with 400 grit discs on a da...your only problem may be that as i mentioned above if it is in 2k then its quite possible that the old red paint will bleed through, then you will have to go down the primer route.. Quote Share this post Link to post Share on other sites
