phorbiuz
Swapping doors
Hi
Anyone know the simplest and quickest way to swap rear doors on a mk3? I haven't had a look at mine yet to see how its done, but I know I need a very quick turnaround to take a rear door off and put on a complete replacement.
I'm thinking that maybe the door post trim can pop off and I can easily get access to captive nuts for the hinges, or maybe the reverse on the door side.
Anyone know the quickest and easiest way?
Ta.
Edited by phorbiuz
Hi
Ta.
I recently refitted the rear doors on my mk5 estate and tried two different methods. On one side I opened the front door and undid the bolts that hold the rear door to the hinge and on the the other side, I removed the door post trim and undid the five nuts that hold the hinge to the b post. Of the two methods, I found the latter much quicker and easier. :oops:
door post trim and undo the nuts...when you put it back on shut the door so its engaged with the catch get a nice gap round the door edges then do the nuts up..sounds obvious i know...
