tc1
door seals mk2 4 door
Hi I have just received my door seals from East Kent Trimmers. When I placed my order I was told they would have a moulded corner and the rest is glue on. Well all I got was a rubber strip with no shaped corner. Has anyone else brought from them and was theirs moulded or not. Hope the headlining is ok and the rets of the stuff I ordered cheers trev
I don't know what the general opinion of EKTS is
I have picked up on a few comments they mmay not be the best bu tnothing directly slagging them off??
If your not happy give em a call
I need some similar bits and windscreen rubbers which Iwould get off them unless anyone says NO????
If you go on the buysell section for parts suppliers this is East Kent Trim's rating:
1 Poor [ 0 ] [0.00%]
2 Below average [ 3 ] [10.00%]
3 Average [ 5 ] [16.67%]
4 Above Average [ 8 ] [26.67%]
5 Excellant [ 14 ] [46.67%]
I cannot comment as i've not had to use any of their products but would agree that they gey some positive and some negative feedback on buysell. Some products do not fit as well as hoped i believe.
Edited by H Cortina
the door seals that east kent trim supply for MkII Cortinas are far too big and bulky, so have two main problems. The first being that they don't clear the striket plate/lock catch assy (only way around is toi trim a big lump out of the new door seals) the other being that once you do get clear of the striker palte, the door won't shut anyway!
Re - headlining. the one I had from them, while well made, was made far to long - around 50mm across the whole length. That might not sound much, but its enough to gaurantee it'll be saggy. I found them not so much "unhelpful" when I questioned this, as totally unreasonable! I was told that it had been made from an original Ford pattern and that I must have been fitting it wrong! In the end, the only optional available to me was to get it re-sewn, so removing 20mm out of the front couple of panels, and 10mm out of the others.
this pic shows just how bad it was - the front support is leaning forwards, the rear support leaning backwards, yet the material is still loose, and I was doing it wrong :thumbup:
and with the seams re-done, and not fully tensioned....
tis highly likely I'll never use EKT again, not because of the mistake, but because of their attitude over this.
I HAVE 1 WORD FOR EAST KENT TRIM .............. CRAP... :thumbup: :thumbup:
the best door rubbers come from the 1600e club they have the corners moulded and the pins to clip them in
http://www.mk2cortina-1600e.co.uk/index1.htm .. and if your not a member then join :thumbup:
I read somthing about Rubbers are out of stock now
Not sure which ones though???
It was in the latest edition of the executive
this pic shows just how bad it was - the front support is leaning forwards, the rear support leaning backwards, yet the material is still loose, and I was doing it wrong :spidy:
How much was the headlining and what material is it ?
can't remember price (£100ish, but no idea how "ish"). With the proper material not available, and not really wanting to go for the series II type, I went for the alternative he offered. I seem to remember him refering to it as "putty", but not sure if thats just in relation to the colour of it or an actual name. Colour is pretty close to the original type material though, and doesn't look at all out of place
£74.75 now
I think some of their stuff has come down in pricelately???
Scroll down this page
EKTSupplies
Well if anyone needs one that wont need the sewing redone
have a couple more of these coming
Same problem as EKT with material though you just cant get the original stuff , ours is off white with pinhole pattern think its original to mk1 Escort
£100 INCLUDING UK postage - EKT price will be plus VAT ? and postage
IF anyone can find any original material it would be greatly apreciated.
I HAVE 1 WORD FOR EAST KENT TRIM .............. CRAP... :winner: :P
http://www.mk2cortina-1600e.co.uk/index1.htm .. and if your not a member then join :spidy:
i will be on the phone to them in the morning to see what they say i spent £320 so not very happy at the moment any one now if the 1600 e owners club have them in stock cheers trev
£74.75 now
don't forget that mine would have been a bit more because the estate roof is longer than the saloons
i will be on the phone to them in the morning to see what they say....
good luck!
do let us know how you get on
good luck!
i just rang east kent trimmers matey was not very helpful at all. He told me that i got it wrong he never said they come with moulded corners and you have to make your own up. Well thats crap! He then said if your not happy send them back. i opened the headlining and laid my old one top the new one is a lot bigger but all the seams line up so with a bit of triming it may fit. i remember buying one for my mustang and it fitted like a glove perhaps the americans take more pride in what they sell! Going to ring the 1600e owners club tonight hopefully they got some cheers trev
