bugsntinas
mk4 indicators
hope someone can help.we have this annoying problem with the indicators and it's peeing us off.it is as follows:
they work fine for days then the wife comes home from work all'swell.i take boys to school they don't work.i get home park up still not working.go out later to sort them they work :thumbup: .now i could understand if there was a loose wire and when ya hit bumps they stopped but they change when parked up.the hazards work all the time regardless of indicators.please help.
got a spare switch that you could try ???? :thumbup:
replaced the indicator swich/arm as the old one was a bit worn.thought it might be the relay switch but surely that would fail out right?
relay points sticking,pssably? my estate did it on and off for ages till i could be botherd to change the relay, try hitting the relay when they dont work see it it helps, it's on the bonnet release handle mount :closedeyes:
relay points sticking,pssably? my estate did it on and off for ages till i could be botherd to change the relay, try hitting the relay when they dont work see it it helps, it's on the bonnet release handle mount :angel_not:
cheers i'll give it a go.trouble is upto now whenever they don't work and i go out to them they work :closedeyes: .might see if i can get a new relay.
Had the same problem with a mk2 escort a few years back and it turned out to be a dodgy hazard light switch. Could be worth trying another one of them.
i'll try that one aswell.been thinking about it as it done it again today surely it wouldn't be the flasher unit 'cause the hazards work when the indicators don't.could it be a short in the instrument panel do ya think?
hazzards where working on mates transit last week but indicators where playing up?
did he find a solution?
dodgy stalk replaced
Had this problem a few times always turned out to be hazard light switch playing up even though hazard lights worked well
replaced the hazard switch the other week and it seemed to cure it.unfortunately i've sold the car. :(
