nogE
Going back to RUBBER
after the trip to the yat the weekend i think i,m gonna change the polys and go back to gen ford rubber stuff...its just that through towns/quiet roads that had holes/bumps in them made the car feel too hard/solid......all suspensions standard...so alls well there....and the remember having a chat with IAN27 a while back and he was saying the same thing....
is there any opinions on this subject?...
and i be looking to collect the bushes etc..... as i have a rear anti roll bar i,ll be needing bushes to suit... i,m trying to get me head around what i,ll need again.... bushes that is.... mk4 lower arm bushes etc.....
dave...what arms do you have?.... may just shot blast/coat and fit new gen bushes in them and straight swap then....keep others for new pro????
Only my opinion but (here goes):
1. Have you thought of keeping the axle end Poly on the rear and going rubber on the front end of the rear axle arms (both top and bottom). Seems to be a popular option for a better ride and to minimise the issues that sometimes occur on the axle mountings on the body?
2. On the front stay with Poly on the front TCAs (standard bushes are rubbish) and on the subframe mountings. Never tried Poly anywhere else on the front.
3. Last piece of advice, having run both Hyundai and Ford rubber bushes on the rear axle upper arms - get the front bushes from a Stellar, they're much better than Ford ones.
now thaTS INTERSTING..... i,d love to leave the subframe poly....and have half/half as it were..... need to investigate this more it seems..... as its all news to me.... and you say stellar are better than ford ones....thanks m8.....looking in to it now :thumbup:
Couple of interesting comments here: http://www.buysellcortina.co.uk/forums/index.php?/topic/38676-my-rear-end/page__p__346964__hl__polybush__fromsearch__1#entry346964
and here:
http://www.buysellcortina.co.uk/forums/index.php?/topic/28607-bushes-and-chassis-cracks/page__p__259182__hl__poly__fromsearch__1#entry259182
Quite a lot of info if you search "poly" on the forum
PM me if you want a photo and part number fot the Stellar bushes, that will show you the difference
I poly the subframes and te rear end but leave the subframe to chassis normal rubber
i leave body mounts on subframe & axle to body in rubber poly others.
and here:
cheers all....i,ll come back on this...need to look at all ideas... :thumbup:
Gary i allways use a rubber so should you :thumbup: .
JESUS......WISH YOU HAD TOLD ME THAT 15YEARS BACK.......
I ve taken most of the poly bushes out of my mk5 and put rubber back in - in time when they need replacing I'll have a go at drilling holes in the poly ones and put them back in - deflex in my experience nearly always need a lot of trimming - the steering rack ones are impossible to fit and the front upper rear arm bushes are ridiculously thick....
oh yes...i know what you mean about deflex ones....mine were hell...tho all in now i want them out... i have fitted a couple of superflex polys...they were better....
i decided to go rubber where the arms/crossmember is bolted to the body... mean changing 8 rubbers.... collecting them now.... need subframe rubbers ...so if you or anyone knows of nos .....pm me please.. :thumbup:
I heard on good authority its best to polybush the front end if you want, but leave the entire rear end rubber as the design of the suspension system needs the movement rubber provides there.
