G.O
Pics from previous trips
Hi,in 1998 in my MK1 Lotus AHC I had no problems,in 2002 Crayford KRA I had head cracked between valves on No4 cylinder,in 2007 again in KRA I lost all cluch fluid just outside Goriza and drove the rest of the trip home with no clutch,Audrey was panicing all the way home.On my last trip to Angouleme a bolt came out of my air filter and went down my carb,I got the bolt but the washer went into No4 piston this was at the first stop at St Nazaire with 1600miles still to go.I took No4 plug out and pushed my magnet on a stick into the plug hole pulling out two pieces of washer with a small piece missing.I started the engine with the plug out from under the bonnet and gave it a good thrashing,then SorB I put the plug back and started it up again and all seemed OK it must have blown out of the exhaust valve, change underpants.Got back home and wilLucySchool072.jpgl strip down ready for next trip to Laon in May 2012.Ron.
hi ron hows things in sunny blackpool ar you and audrey going to cortina in 2012?
regards mike bno746g.
Hi Mike, nice to hear from you hope you or both keeping well as we are here,yes we are going to Cortina there or two starting points,Geoff from Leeds and about seven cars or sailing from Hull, and the others or sailing from Dover and you can get all information on this site or from the MK2 web site and GO is the man to keep you informed.Ron. ps hows that lovley car of yours.
Edited by RONV
These photos are outstanding, most enjoyable to look through and gaze at the magnificent cars against the magnificent backdrops.
