dan 67 tin corner 1600e :) 0 Posted August 29, 2011 drove about 60 miles today and sudenly started loosing power through all gears. i had to pump the pedal to keep her going or keep my foot to the carpet.. as soon as it goes over 1500 rpm the carb makes a sucking sound then wants to cut out. theres plenty of air its like its not getting the fuel??, even though theres plenty of fuel getting to it. im running a 32/36 dgav which i referbed 5000 miles ago and has been fine, on the 1600 crossflow ?? cheers. Dan. Quote Share this post Link to post Share on other sites
Steve E 0 Posted August 29, 2011 Check the crank case breather pipe for splits if its drawing air it will be very poor Quote Share this post Link to post Share on other sites
dan 67 tin corner 1600e :) 0 Posted August 29, 2011 ok will do tomorow cheers :) Dan. Quote Share this post Link to post Share on other sites
S1ReDR 1 Posted August 29, 2011 Check for sediment in the float chamber of the carb , fit an in line filter and check the accelerator pump diaphragm. Quote Share this post Link to post Share on other sites
dan 67 tin corner 1600e :) 0 Posted August 30, 2011 nothing wrong with the crankcase breather in good nick checked for sediment nothing cleaned the filter out, i only changed the accelerator diaphram a couple months ago, could it have siezed or something? Quote Share this post Link to post Share on other sites
3litrepete 2 Posted August 30, 2011 It may be that the breather for the tank - probably in the cap, is blocked causing a vacuum in the tank, quick check is when it does it again, quickly take the cap off & you may hear air rush into the tank, then try starting the car & see if it has improved, Hope this helps, Quote Share this post Link to post Share on other sites
DHV571D 16 Posted August 30, 2011 Sounds like the distributer condenser failing to me.... Quote Share this post Link to post Share on other sites
dan 67 tin corner 1600e :) 0 Posted August 30, 2011 Sounds like the distributer condenser failing to me.... ok ill have another look tomorow, how could i check the dizzy condenser? and what fails exactly? not really familliar with this part? cheers, dan. Quote Share this post Link to post Share on other sites
cortina mungo 0 Posted August 30, 2011 I am not dismissing any of the above, but it could also be the filter in the tank, on the end of the pick up tube. these can somtimes cause funny running problems. I usually take them off and fit an in line filter towards the rear of the car somewhere near the tank. It might be worth a try. Quote Share this post Link to post Share on other sites
DHV571D 16 Posted August 30, 2011 Sounds like the distributer condenser failing to me.... ok ill have another look tomorow, how could i check the dizzy condenser? and what fails exactly? not really familliar with this part? cheers, dan. The Condenser is there to smooth out the spark and stop points erosion, when they start to break down the symptoms are that the car will tick over all day but is very reluctant to rev above about 1500 rpm and the engine power is very low. If it is the condenser going the points will fail very soon, usually they weld themselves shut. Best way to check the condenser is to replace it with a good spare or get one off ebay, should only cost you a couple of quid. Quote Share this post Link to post Share on other sites
paulsv24 0 Posted August 30, 2011 Had this on mine a few years back, might be worth having a look at the little filter isn't blocked/dirty in the carb. It's located behind a big brass cap (approx 15mm spanner size) and it's usually under the fuel inlet hose connection. Best of luck with it :thumbup: Quote Share this post Link to post Share on other sites
dan 67 tin corner 1600e :) 0 Posted August 30, 2011 Sounds like the distributer condenser failing to me.... ok ill have another look tomorow, how could i check the dizzy condenser? and what fails exactly? not really familliar with this part? cheers, dan. The Condenser is there to smooth out the spark and stop points erosion, when they start to break down the symptoms are that the car will tick over all day but is very reluctant to rev above about 1500 rpm and the engine power is very low. If it is the condenser going the points will fail very soon, usually they weld themselves shut. Best way to check the condenser is to replace it with a good spare or get one off ebay, should only cost you a couple of quid. ah no sory my mind went blank there, im running an (accu spark) electronic ignition so no points or condensor, and a new coil. it deafinatelly sounds like the carb because it only happens when the engine warms up and the chokes open up, not enough fuel to match the air. but by looking in the top of the carb, and pumping the throtle, fuel squirts out the top jets as usual. but seems strange that it performes as usual when my foots beded right to the floor?? Quote Share this post Link to post Share on other sites
MK5 V8 1 Posted September 1, 2011 maybe a blockage in the fuel line Quote Share this post Link to post Share on other sites
