ginger01 0 Posted February 8, 2012 I am thinking of converting my 1964 MK1 1500 DELUXE to an alternator and i would like some advice please, i know that i have to convert the car to neg earth and swap the coil connections but i am unsure if any other component needs its polarity changing. I would also like to know what alternator will fit /what brackets i need for the new alternator and can the control box under the parcel shelf be removed or does it need to be left in situ but modified, and does any member know where i can obtain the parts i need for this conversion or does anyone on here have the parts i need for sale? i would prefer good second hand parts to keep the costs down. Many thanks :thumbup: Share this post Link to post Share on other sites
Derskine 11 Posted February 8, 2012 I am thinking of converting my 1964 MK1 1500 DELUXE to an alternator and i would like some advice please, i know that i have to convert the car to neg earth and swap the coil connections but i am unsure if any other component needs its polarity changing. I would also like to know what alternator will fit /what brackets i need for the new alternator and can the control box under the parcel shelf be removed or does it need to be left in situ but modified, and does any member know where i can obtain the parts i need for this conversion or does anyone on here have the parts i need for sale? i would prefer good second hand parts to keep the costs down. Many thanks :thumbup: I am in the process of doing this to my car, you will need everything you see here (you can buy this kit but it can be done cheaper), http://www.105speed.com/default.asp?id=123 the bracket is from a later crossflow engine, ie a late mk1 escort, mk2 escort, early fiesta etc. The tensioner is from any of these too, the alternator belt I have is for a mk2 escort. I have yet to tackle the wiring as I still need to get my engine running :thumbdown: however it doesn't seem hard, just don't forget the wire from the alternators positive feed to the positive terminal of the battery http://freespace.virgin.net/tommy.sandham/alternator_conversion.htm If you haven't read this you should! Share this post Link to post Share on other sites
bortaf 96 Posted February 9, 2012 this might help ? Share this post Link to post Share on other sites
gixsermalc 1 Posted February 9, 2012 Hi im in the middle of doing this myself and am having some problems. this is on a 64 pre airflow mk1 we have joined the 2 brown/yellow together and the two browns together. now the idiot light stays on with the ignition off but and goes out when the car is running. we have wired the alternater to my mates mk3 and it didnt light the idiot light when connected but not fully fitted so could not check if actualy charging but asumed all is good as not showing same fault as when in the mk1. We have 7 wires at the regulater my friend who is doing this conversion did this to his mk1 years go as far as he remebers this is how he did it, but the link to the way Tommy sanderson does it is completly differant is Tommys way the only way to do it and my mate is wrong. Many thanks Malc Share this post Link to post Share on other sites
Derskine 11 Posted February 9, 2012 Hi im in the middle of doing this myself and am having some problems. this is on a 64 pre airflow mk1 we have joined the 2 brown/yellow together and the two browns together. now the idiot light stays on with the ignition off but and goes out when the car is running. we have wired the alternater to my mates mk3 and it didnt light the idiot light when connected but not fully fitted so could not check if actualy charging but asumed all is good as not showing same fault as when in the mk1. We have 7 wires at the regulater my friend who is doing this conversion did this to his mk1 years go as far as he remebers this is how he did it, but the link to the way Tommy sanderson does it is completly differant is Tommys way the only way to do it and my mate is wrong. Many thanks Malc Tommys way is for an aero-flow car with the regulator mounted on the inner wing, it's different for a pre-aeroflow. Share this post Link to post Share on other sites
gixsermalc 1 Posted February 9, 2012 i know the differance in location of regulater is that the only differnace? Share this post Link to post Share on other sites
Derskine 11 Posted February 9, 2012 i know the differance in location of regulater is that the only differnace? Not sure, I know the regulators are different, I have 6 wires going to my regulator on the inne wing :headscratch: Share this post Link to post Share on other sites
gixsermalc 1 Posted February 9, 2012 Not sure, I know the regulators are different, I have 6 wires going to my regulator on the inne wing :headscratch: I have 7 wires to mine inside the car. i knew i should have stuck to VWs Share this post Link to post Share on other sites
Derskine 11 Posted February 9, 2012 I have 7 wires to mine inside the car. i knew i should have stuck to VWs I have just tackled most of the wiring, I still need to put a positive feed fom the altenator to the battery, waiting on a ring terminal. I didn't join any wires together, I just peel back the secondary loom to the dynamo and back into the main loom, I disconnected the wires from the regulator and when I peeled it back they simple just fell off, I was left with two wires, a yellow/brown and a thick brown one, I taped up the thick brown one because its not needed, and extended the yellow/brown one to the alternators warning light connection. I have yet to hook up the sensing connection/positive feed but thats not hard at all. Share this post Link to post Share on other sites
gixsermalc 1 Posted February 10, 2012 Way hay all sorted boy was that easy. forget the way its says its done in the mags and on variouse sites the way on the tommys databook is correct though we did it a simpler way and left all the wires there just in case it needs to be returned to standerd.(new VOSA regs and all that). we removed the wires from the regulater and tapped them up just in case, double checked the colour of wire to the idiot light, then joined two wires together going into one which we fixed to the positive terminal on the battery then fixed the 2 wires to the alternater job done kettle on. Share this post Link to post Share on other sites
garm 0 Posted December 28, 2015 Thanks for this thread, I think I'm going to have to do this soon. Generator (dynamo) is making some funky noises. Share this post Link to post Share on other sites
the-ford-cortina.com 226 Posted December 28, 2015 Thanks for this thread, I think I'm going to have to do this soon. Generator (dynamo) is making some funky noises. I can get you a reconditioned alternator and should have the brackets , PM me a list of all the stuff you need for your car and I might as well get a few together and post in one hit Share this post Link to post Share on other sites
