markanglia
Mk2 legs
Hi I have a pair of gaz mk2 cortina legs on my 100e with mk2 hubs . Is it Granada callipers and capri vented discs ???
capri 2.8i had spaced m16 calipers to take the 2.8i vented discs I believe, if we're talking about the same thing here :headscratch:
With the Capri 2.8i vented discs, you can use Capri 2.8i calipers (Girling M16 with spacers), or Granada 2.8i calipers (Girling M18 with spacers).
The Granada calipers have bigger brake pads, so will work even better than the Capri calipers.
You will also need the longer Capri 2.8i caliper mounting bolts and the Capri 2.8i 5mm wide spacers (large/thick washers), which go between caliper and front strut (to centralize the caliper over the wider vented discs).
And you will need a new brake line from caliper to strut (metric nut at the caliper end).
