2.0ltrMk1Cortina 3 Posted May 12, 2012 Well I have finally finished fitting the efi kit to the pinto in my mk1 estate, the car was fitted with a injection (205) pinto when I got it from Dave but on a 32/36 twin choke webber carb so I sourced all the efi stuff to fit back on. I did a efi pinto conversion on a anglia many moons ago and it was a awesome car to drive and go and had this planned for the Cortina from the start. Also fitted and wired the GT clocks and pod, just need to re-paint all the dash next. The efi conversion took me a little longer than I had planned as I ended up sorting lots of other little niggles while various parts were removed. Drove her for first time since completing efi install and have to say she goes a lot better than before and is much smoother. :thumbup: Heres some pics. Engine bay as when bought from Dave, Engine bay as of now with efi, Ecu position under dash, Re-modified throttle pedal to except Granada efi pinto cable, And Gt clocks fitted, 1 Quote Share this post Link to post Share on other sites
G.O 20 Posted May 13, 2012 Coming together nicely :D Quote Share this post Link to post Share on other sites
AERO_ADY 10 Posted May 13, 2012 Better MPG too :thumbup: Quote Share this post Link to post Share on other sites
jordan98 9 Posted May 13, 2012 Better MPG too :thumbup: with a bit more BHP to :thumbup: Quote Share this post Link to post Share on other sites
2.0ltrMk1Cortina 3 Posted May 13, 2012 Cheers guys :thumbup: I'm hoping for more MPG as its a bit of a daily driver. The efi pinto I had in a anglia a few years back would return a easy 55MPG on a run. :thumbup: 1 Quote Share this post Link to post Share on other sites
AERO_ADY 10 Posted May 14, 2012 Cheers guys :thumbup: I'm hoping for more MPG as its a bit of a daily driver. The efi pinto I had in a anglia a few years back would return a easy 55MPG on a run. :thumbup: I was getting a good 40 mpg combined in my mk1 escort Quote Share this post Link to post Share on other sites
63tina 0 Posted May 17, 2012 Top Man Romany, your craking on with the work,just need that interior sorting out and she'll be even better, :thumbup: Quote Share this post Link to post Share on other sites
corsair 21 Posted May 17, 2012 38 mpg regularly from mine. As a matter of interest you can get rid of that convoluted factory intake pipe and replace with house rainwater down pipe, just warm up the end with a hot air gun and push firmly onto pleneum, as you already have a short rubber pipe to the airflow meter this should give enough flex any bends can be done with same elbows and plastic welded together. My engine is 2.1 with no fan and a performance air filter and was rolling roaded at 128bhp which is quite adequate. Paul Quote Share this post Link to post Share on other sites
2.0ltrMk1Cortina 3 Posted May 18, 2012 Top Man Romany, your craking on with the work,just need that interior sorting out and she'll be even better, :thumbup: I've started on it Dave, made new door cards, just need to cover them and I've started painting all the dash and other interior metalwork. Still looking for a front parcel shelf to finish it off. Had a powerflow stainless exhaust system madeup for it yesterday too. Sounds well nice now. :thumbup: Quote Share this post Link to post Share on other sites
Llohcins 0 Posted February 11, 2024 Hi, I know this is a long shot as this thread is so old but just in case you are out there still. I am about to do this conversion on my mk1. I’m getting ready to offer in the pinto and type 9. Do you have any tips on this or maybe old photos of where to cut the tunnel for the box? That is assuming you are using a type 9. I’ve got the same efi setup on the pinto ready. Thank you Quote Share this post Link to post Share on other sites
Osgood71 0 Posted June 29 Hi I am trying to do the same thing but I a Corsair I think I have all the parts but I am struggling with the wiring Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 767 Posted June 29 I think I've still got the diagram once you've plugged everything back in you need I think it's half dozen wires. Quote Share this post Link to post Share on other sites
dgo 80 Posted June 30 14 hours ago, Osgood71 said: Hi I am trying to do the same thing but I a Corsair I think I have all the parts but I am struggling with the wiring I replied to your other thread (This one) with a link to a good diagram showing the wiring connections Quote Share this post Link to post Share on other sites
Osgood71 0 Posted June 30 Hi if you have a good wiring diagram that would be great. Has I have wires and no clue where they go but I also think I am missing wiring for the ecu relay and fuel pump relay.thanks all for your help Quote Share this post Link to post Share on other sites
