chris1800 0 Posted May 27, 2012 hi i am about to start fitting a type 9 to my mk5 cortina that is fitted with a 1.6 pinto have everthing apart from the prop can anyone help or have any advice the prop i have is a standard 1.6 prop. cheers chris Quote Share this post Link to post Share on other sites
adrianb 0 Posted May 27, 2012 hi i am about to start fitting a type 9 to my mk5 cortina that is fitted with a 1.6 pinto have everthing apart from the prop can anyone help or have any advice the prop i have is a standard 1.6 prop. cheers chris I *think* the output shaft of the type 9 came in two different sizes - it is larger on the 2.0l. I have a two-piece prop from 2.0 for sale. PM me if you find you need one. Quote Share this post Link to post Share on other sites
jaymk5 0 Posted May 27, 2012 I *think* the output shaft of the type 9 came in two different sizes - it is larger on the 2.0l. I have a two-piece prop from 2.0 for sale. PM me if you find you need one. the type 9 out put shafts are the same size 1.6 and 2.0 but cortinas are diffrent the 2.0 is bigger you need a prop from a manuel 20/2.3 cortina or from any late mk3 auto or any autp mk4/mk5 :superman: Quote Share this post Link to post Share on other sites
dgo 66 Posted May 27, 2012 the type 9 out put shafts are the same size 1.6 and 2.0 but cortinas are diffrent the 2.0 is bigger you need a prop from a manuel 20/2.3 cortina or from any late mk3 auto or any autp mk4/mk5 :superman: I have the front half of a standard 2 litre prop with a doughnut yoke. Where abouts are you? Quote Share this post Link to post Share on other sites
chris1800 0 Posted May 28, 2012 I have the front half of a standard 2 litre prop with a doughnut yoke. Where abouts are you? hi i am in norhtern ireland if you would be able to get us a price including postage to bt42 3hz that would be great is the front part of the 1.6 prop with the rubber donut in it interchangable to the 2.0 front prop. cheers chris Quote Share this post Link to post Share on other sites
dgo 66 Posted May 28, 2012 hi i am in norhtern ireland if you would be able to get us a price including postage to bt42 3hz that would be great is the front part of the 1.6 prop with the rubber donut in it interchangable to the 2.0 front prop. cheers chris Can you post a photo of the front of your axle? Does your doughnut have 3 or 6 bolts? Quote Share this post Link to post Share on other sites
chris1800 0 Posted May 29, 2012 Can you post a photo of the front of your axle? Does your doughnut have 3 or 6 bolts? hi the axle is the standard 1.6 axle not an atlas the donute from memory had 6 bolts in it 3 holding the donute to the prop and the other 3 holding the donute to the spline part that slides into the gearbox hope this is of help :thumbup: cheers chris Quote Share this post Link to post Share on other sites
dgo 66 Posted May 29, 2012 hi the axle is the standard 1.6 axle not an atlas the donute from memory had 6 bolts in it 3 holding the donute to the prop and the other 3 holding the donute to the spline part that slides into the gearbox hope this is of help :thumbup: cheers chris Ok then you have two choices. The axle doesn't make a difference the diff flanges on the Koln and Atlas are the same (at least I've never seen one any different) it's the gearbox output staft that's different on the 1.6 vs the 2 litre and type 9 (the latter 2 are the same). A good number of people have found that the standard doughnut prop from a 2 litre will be OK with a type 9, some have found the doughnut bolts foul on the type 9 as it's a bit longer than a 4 speed box. So your choices are: 1. Probably the cheapest way to do this, you can remove the 1.6 flange and replace with the 2 litre one. Assume you know about needing to put a strap/jubilee clips around the doughnut to stop it expanding when you remove the 1.6 flange. Good chance this will work OK. 2. If you want to be absolutely certain of success you need to get hold of a Capri/Cortina auto prop with the UJ front rather than the doughnut version but this will cost a lot more with a front like this: http://rover.ebay.com/rover/1/710-53481-19255-0/1?ff3=4&pub=5574629005&toolid=10001&campid=5335900709&customid=&mpre=http://www.ebay.co.uk/itm/FORD-CORTINA-MK-3-4-5-1-6-2-3-PROP-SHAFT-MANUAL-/300710780708?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4603c25f24 If you want to go down route 1, I have a flange I can part with. pm me your number and I'll give you a call over the weekend to arrange if you'd like Quote Share this post Link to post Share on other sites
chris1800 0 Posted May 30, 2012 Ok then you have two choices. The axle doesn't make a difference the diff flanges on the Koln and Atlas are the same (at least I've never seen one any different) it's the gearbox output staft that's different on the 1.6 vs the 2 litre and type 9 (the latter 2 are the same). A good number of people have found that the standard doughnut prop from a 2 litre will be OK with a type 9, some have found the doughnut bolts foul on the type 9 as it's a bit longer than a 4 speed box. So your choices are: 1. Probably the cheapest way to do this, you can remove the 1.6 flange and replace with the 2 litre one. Assume you know about needing to put a strap/jubilee clips around the doughnut to stop it expanding when you remove the 1.6 flange. Good chance this will work OK. 2. If you want to be absolutely certain of success you need to get hold of a Capri/Cortina auto prop with the UJ front rather than the doughnut version but this will cost a lot more with a front like this: http://rover.ebay.com/rover/1/710-53481-19255-0/1?ff3=4&pub=5574629005&toolid=10001&campid=5335900709&customid=&mpre=http://www.ebay.co.uk/itm/FORD-CORTINA-MK-3-4-5-1-6-2-3-PROP-SHAFT-MANUAL-/300710780708?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4603c25f24 If you want to go down route 1, I have a flange I can part with. pm me your number and I'll give you a call over the weekend to arrange if you'd like pm sent :thumbup: Quote Share this post Link to post Share on other sites
dgo 66 Posted June 4, 2012 pm sent :thumbup: OK just found my spare yoke: Quote Share this post Link to post Share on other sites
dgo 66 Posted June 5, 2012 OK just found my spare yoke: OK per your pm, here's a photo fitted to a spare type 9 box I have: Quote Share this post Link to post Share on other sites
