Duke Blues
paint your wagon.
Great advice Craig cheers
Another problem I found when priming the engine bay was access. Not so much of a problem with primer. But with met paint I understand that the gun needs to be about 8 to 10 inches from the panel. Sometimes I couldn't get that close without the top tank or airline connector rubbing on other parts of the bay. It's hard to imagine how you can keep an even distance from the panel with all those nooks, crannies and awkward to reach areas. I know I'm becoming a bit of a bore but there's a lot more to a paint job than first appears.
in tough to get in areas turn your gun onto spot spray , youll notice that the pressure sounds to have increased so youll need to turn it down a bit then turn down the fluid delivery so you cant over apply the paint, do the tricky areas first with a couple of coats then open the guns fan and fluid delivery back up and paint the rest of it. regards craig
evry ones got to make a living and craig is no exception but of all the stuff i've read yours has come across as the most honest. i realy do appreciate your input. and from reading your posts i find it easier to put this together in my own mind. if you've got the cash and you live nr doncaster go to craig. if your like me and a bit short of funds then i wish you luck.
i'm a mile away from making my mind up but. tick tick tick.
times catching up with me. :shocking:
