Danish
Mk3 Endurance Rally project
Jayne
Is there any way you can get a deeper water pump pulley made same diameter so you can use the larger diameter rear section of the crank pulley?
I need the rear pulley for my supercharger!
Could you share it with the water pump as you need them both at the same time?
Nope, I want as close to 180degree contact between belt and sc pulley as I can. It takes something like 30bhp to run it at max rpm.
Keep the ideas coming though :-)
Electric water Pump which you have already?
A good idea. I'd just have to get something to fit where the water pump is. Maybe get an alloy water pump, cut it and have a plate TIG'd on.
Or I suppose I could remove the impeller and use the rest as an idler pulley.
Remove the pump and get a plate made with a tube on it to feed the water to the rad so it will still circulate.
If you just remove the impeller you still have the possibility of leaks due to the shaft and bearings.
I like that. The pump is 19mm bore, so I'd have to have a think about what size to do the take-off pipe. Or looking at the photo again,just cut off the front part, fill up the hole with a metal plug and weld, and use the existing pipes.
Edited by Danish
I am somewhat stunned... opened this month's Classic Ford magazine this evening and we've only gone and been voted Classic Ford of the Year!
Thanks to everyone who voted for the car, and to SWMBO and the local crew who helped whenever I had something heavy or difficult to do!
:cheers:
:winner:
A lot of effort has gone into the car. Well deserved Jayne - it's pretty frikken awesome!
I thought you had a very good chance from the start - all the guys on the forums were lining up to show their support.
Not wanting to detract from your win at all but I have to say, the competition was pretty poor this year. Nothing tickled my fancy other than the Sundowner Van and even that was before I realised it was a real thing - initially I thought it was a custom fan-fiction what-if type of project like yours Jayne. They are nice cars all of them but not a patch on yours. Classic Ford need to pull their fingers out and find some more interesting cars for next year IMHO.
Edited by Kenworth W900
Cool
:thumbup:
Well done!
Congrats Jayne. Well deserved for all the work you have put in.
