Messer
Wiring connections mk1
Where can I find a good wiring diagram for a mk1 GT? My loom has been disconnected when removed from the car and need to make sure that the right connections are made at the joins (presume its done continuation of colour so green/white goes to green/white for example.
Also I need to know how the wires goin to the front connection box under the slam panel too.
Thanks
I couldn't find a decent wiring diagram only
the workshop manual.
Wires at front should have bullet connectors
and push in,clean them up first.
What have you done about your headlining,need to
get mine sorted soon.
Bob
I used these connectors from halfords for the grey front connector block at the slam panel,take the new metal sleeves out of these new connectors & push them into the original grey connector block, saves trying to clean up the old connectors.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_196283_langId_-1_categoryId_255229
Thanks, the connectors I have are in decent shape though really - I was more worried about the colours and what goes where but like the tips on the connectors though :)
I haven't had to redo the headlining in mine as its in good shape but am looking for ideas on how to clean it up - cif is supposed to be decent?
Can anyone tell me what connects to what in the
Multi connector please?
Messer, I'll look at the plug on mine tomorrow and let you know, its just lights, indicators for front i think, an i might have a gt diagram as well somewhere?
Nice one thanks that's a good help.
Cherrs
Tony - simples - just get a couple of wires (1 black earth & 1 red live)& a bulb holder - the earths are black & the colours are the live.
Earth out all the blacks.
Then just go through the output wires from the block to the lights one at a time with the red live and you'll see what comes on.
Then do the same with the loom ends coming in to the block using an earthed bulb holder - as you switch the switches, the bulb will light up.
Then match them up in the block. Mains Dips Sides Flashers
Edited by Keith Halstead
connection block has 8 holes each side, standing in front of car mine is wired as follows, but remember mine is pre-airflow deluxe
on l/h side of connector block
1st 2 holes Blue with red tracer
2nd 2 holes Blue with white tracer
3rd 2 holes Red in one hole
4th 2 holes 1st hole Green with red tracer, 2nd hole Green with white tracer.
on r/h side of connector
1st 2 holes 1st hole Blue with red tracer
2nd 2 holes 1st hole Blue with white tracer
3rd 2 holes Red in both holes
4th 2 holes 1st hole Green, 2nd hole Green with white tracer.
wiring diagram to follow later, might need yr email to send it too
Pete
Just for info,
- If you need parts & accessories for loom repairs etc..
I have used the following stores, and can recommend them..
I have had no problems with them, - they always have what I need, and will use again..
I need to place an order soon actually.. lol..
http://www.autoelectricsupplies.co.uk/search?search_string=bullet&x=0&y=0
http://www.autoelectrics.net/wiring.html
regards, Kev
sorry idont have this to post up , maybe some else , the big old type workshop manual shows the dash wiring in its component form looking at it as if you are behind the wheel so to speak , helpfull to recognise the bits and plugs .
Messer, was the wiring diagram any good?
Sorry, had parked this job whilst waiting for some grey loom
Tape to turn up :) it will help yes thanks - but can't see where the connector block is though?
The slam panel connector block is at the top centre of the wiring diagram, five black blocks, one above the other.
