J2S
Mk3 2 dr x 2
Epoxy primed engine bay and stripped
and rust proofed under floor
Epoxy primed a tad more
I bare metal then a heavy coat of rust eater then a few days later I use a soft nylon round wheel in a drill and clean up metal again brings in up very clean
you can see fitst pic where I’ve started , I then put a rust proofer on a scotch bright do it goes on smooth like the picture above
4AB453C2-6A4E-46A2-B158-F6D7483CC50F.thumb.jpeg.8d952c3229f88e69cfd8c03f4330d606.jpeg0EB9055F-999A-4A80-9C47-A13E2AFD9275.thumb.jpeg.44fae3b2dc7a606c9a1a06c6f22303f8.jpeg6D3B0239-E74F-484B-88DC-F13BDE71F616.thumb.jpeg.96da634295b147c72b341f2681efa3a3.jpeg
Edited by J2S
  • Like 3
Top work indeed!
Thought I best put some colour in the hard to reach places just started to spot weld it together
Been restoring a 2.8 special Capri for a customer started on engine he wanted factory look
  • Like 2
Bit more on the 2.8 bits
Posted (edited)
Give up on the spot welder anyway it’s all
welded up need to do the lead loading bits
next thing on the spit
Edited by J2S
Great work mate,looking good :thumbsup:
Cheers dean
On the spit it went
all in the prep but Getting the paint right and gun set up for the job your doing helps
just as much
Posted (edited)
Done some stripping rust killing inside
a lot easier on the spit ,taking dash and handbrake out weekend finish off
also started pulling nasty trolly jack dents
out of the  chassis rail run out off gas in the torch so that ended that for now
Edited by J2S
 Crazy times with work at the mow
not touched my cars but managed a few hours yesterday satin black the bumpers and door lock
well acid 8 them ,black Monday
had a couple of sets  cosworth wheels
refurbished be putting the 3 dr ones on
just sorting the big o rings for center cap
be going Chelsea cruise end of the month
Posted (edited)
Done!!
not for the purest but a standard 1.6l just don’t do it for me
Edited by J2S
