Messer 2 Posted November 15, 2012 (edited) As part of my rebuild I need the following parts if anyone can help with a decent price? big ends gaskets big end and flywheel bolts water pump high pressure oil pump dizzy rebuild 8 valve guides valve springs unleaded seats valves steel pulley timing chain crank sprocket rocker assy cam followers Petrol Pump If anyone started a rebuild and changed plans or anything or any of the above you have new or nos etc please let me know Thanks Edited November 15, 2012 by Messer Quote Share this post Link to post Share on other sites
Messer 2 Posted November 19, 2012 Goth the water and petrol pumps stil need everything else? Quote Share this post Link to post Share on other sites
Lotuscops 80 Posted November 20, 2012 I think I have a used steel crank pulley, fuel pump & new sprocket - might have set of cam follwers as well - will check Tony. Quote Share this post Link to post Share on other sites
Messer 2 Posted November 20, 2012 I think I have a used steel crank pulley, fuel pump & new sprocket - might have set of cam follwers as well - will check Tony. thanks Keith, have a new petrol pump but interested in the othe bits if you can let me know a price. Cheers Quote Share this post Link to post Share on other sites
Lotuscops 80 Posted November 20, 2012 (edited) OK Tony - found Crankshaft pulley, sprocket, Rocker shaft, cam followers, 116E conrods with bolts, AC glass tops of petrol pumps if you have a manual solid top one & various used oil pumps (original and screw on canister) but don't know if any are high pressure (one is off a Lotus but no idea if high/normal) - PM or email me what you want & I'll work out a cost + postage. Edited November 20, 2012 by Keith Halstead Quote Share this post Link to post Share on other sites
gsijeff 0 Posted January 17, 2013 As part of my rebuild I need the following parts if anyone can help with a decent price? big ends gaskets big end and flywheel bolts water pump high pressure oil pump dizzy rebuild 8 valve guides valve springs unleaded seats valves steel pulley timing chain crank sprocket rocker assy cam followers Petrol Pump If anyone started a rebuild and changed plans or anything or any of the above you have new or nos etc please let me know Thanks Quote Share this post Link to post Share on other sites
gsijeff 0 Posted January 17, 2013 hi got 120e block bore and fitted new pistons new crank regrind new cam also have head all rebuilt no sump needs putting together £275 collected im in s. wales =jeff Quote Share this post Link to post Share on other sites
Messer 2 Posted January 19, 2013 Thanks but already started the build on mine now and it's nearly finished. Cheers for the reply tho Quote Share this post Link to post Share on other sites
