Cheesychive
Seats upgrade
I used Calibra front seats , ideal for a 2 door
I've got a pair of Recardo's out of a Capri 2.8 inj in the dutch lady at the moment,mind you I had to bolt a piece of 40mm X 6mm flat steel on the one side to bridge the difference between the mounting for the Cortina runners.Not perfect but it works.
On 11/25/2012 at 6:10 PM, Bronxglenn said:
John Mack is right. Scorpio leathers fit str8 in apart from modifying the rear seat base to lower it by about 1.5 inches.
I was lucky enough to get a MINT CONDITION set on EBAY for just £95 + postage.
Only thing is that my car is a 4 door so you might have to play around with the front seats to let big peeps in.
Hi, apologies for resurrecting a very old thread (some forums don't like that, but I don't really understand why it matters??).
Anywho, I am surprised to read that Granada rear seats fitting straight in a mk3. I have never tried, but we used to have a set kicking round years ago, and it looked way to big for the Sierra XR4i I had at the time. What's needed to lower the base?
I need a rear seat for my mk4, and if they fit, then the black leather would be perfect to match the seats I have sourced for the front.
And can I please confirm - is the above referencing the Granada Scorpio (mk3)? Or the later "buy-eye" Scorpio?
Thanks!
Both , you need to make a simple angle iron frame to mount the seat base one.
I have a full MK3 leather int ( the front heated & electric adjustment is wired up) in my MK3 est .
Would just need mechanism modding to tilt for a 2dr or just power them full forward.
Brill, thanks for confirming. I only need the rears. I'll have to see if they a are still in my dad's loft. Thanks!
