skodaboy 3 Posted March 16, 2013 Hi everyone, do any of you chaps have a 2.0l manual propshaft? or better still the front splined yoke from a Capri? I currently have a spline which was left outside to get rained on by the banger bloke I got it from :thumbdown: it does work but its now a little loose on the output shaft, and wearing the rear oil seal out. This was the ideal solution as I did away with the rubber doughnut. Please can anyone help? Quote Share this post Link to post Share on other sites
Gely.66 0 Posted March 18, 2013 ive got the bit between the donut and gearbox if thats what you need? Quote Share this post Link to post Share on other sites
Gely.66 0 Posted March 18, 2013 or ive got a 1600 prop, from the centre bearing forwards Quote Share this post Link to post Share on other sites
skodaboy 3 Posted March 18, 2013 (edited) Thanks lads, :cheers: its been pointed out to me that the part I need is the splined U/J type, also it needs to have 23 teeth in the spline, so the 1600 type wont fit. Needs to be a 2 litre prop spec. Thanks for the offers. so I'am still looking. it should look something simlar to this. Edited March 18, 2013 by skodaboy Quote Share this post Link to post Share on other sites
wayne smith 1 Posted March 18, 2013 i got same 1 on 16 capri lasor Quote Share this post Link to post Share on other sites
littlenewt2067 33 Posted March 18, 2013 i got same 1 on 16 capri lasor they look identical but the 1600 is a smaller diameter :thumbup: Quote Share this post Link to post Share on other sites
PFM1964 5 Posted March 18, 2013 i had a 2.0 ltr end, like the one in your picture, fitted to my 1.6 propshaft by South Wales Propshafts a couple of years back, cost me £100 they fitted it complete with a new UJ www.southwalesprops.co.uk Quote Share this post Link to post Share on other sites
fiatfan 0 Posted March 23, 2013 they look identical but the 1600 is a smaller diameter :thumbup: if the 1.6 laser capri has a type9 gearbox then it has 23spline 2ltr spec front joint Quote Share this post Link to post Share on other sites
skodaboy 3 Posted March 24, 2013 (edited) if the 1.6 laser capri has a type9 gearbox then it has 23spline 2ltr spec front joint I'am confused now is this true? I also believe I have made a mistake in the second post with the number of splines, but what ever it is, it defo need to be 2.0 spec. Sorry... :oops: I still need one...... Edited March 24, 2013 by skodaboy Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 529 Posted March 24, 2013 all type9 5 speeds use the larger 2.0 splines. Quote Share this post Link to post Share on other sites
skodaboy 3 Posted March 24, 2013 all type9 5 speeds use the larger 2.0 splines. Thank you for the clarification. so then, has anyone got one? Quote Share this post Link to post Share on other sites
colin14 0 Posted March 24, 2013 i have a capri 5 spd front half of the prop, make me a offer and could be yours Quote Share this post Link to post Share on other sites
adrianb 0 Posted March 26, 2013 ...and if you can't find what you're after I've got a complete MK5, 2.0l, 2 piece prop with the rubber doughnut. Quote Share this post Link to post Share on other sites
skodaboy 3 Posted March 27, 2013 ...and if you can't find what you're after I've got a complete MK5, 2.0l, 2 piece prop with the rubber doughnut. Thanks but I think colin14 has the part I need, thankyou to everyone who has helped and offered. Quote Share this post Link to post Share on other sites
