ballbag
deluxe top mounts
anybody had to change there front suspension top mounts what do you recomend as a replacement
Hugh Wade used BMW mounts that were better quality & had the bearings inbuilt - bit pricey at £250 - his son John probably has a few left since Hugh passed away.
mk4 zephyr zodiac roller bearing top mounts , you just need to alter the holes on your inner wing tops slightly to fit them. Might be a problem finding some though.
Thats what's fitted on mine, and not expensive either, series one struts they fit straight on, series two struts they need a sleeve machining as far as i'm aware :thumbup:
For a mk1, I believe the owners club do new repro top mounts?
I believe putting mkIV Zodiac roller bearing top mounts on a mk2 would also lower it slightly, not a bad thing!
thanks guys appreciate the help looks like the way to go bmw ones sound a bit to expensive not having stripped them before nothing similar on a mk1 or 2 escort any good?
On a mk1? What's wrong with your originals can't you just replace the bearings?
I've never even looked at them but I thought they just had a replaceable bearing inside?
They have 2 replaceable bearings but the rubber mount part is a bit shot so going to change as a pair
Hello Sir,
i use the BMW mounts, just drill to holes 8.8 mm at the right place, use the original topmount for right dimensions.
The car will be a bit higher, about 2 cm.
i wonder why these parts are so expensive in UK. go to the scrap. the BMW parts last almost forever.don't forget to place the bmw alu washer onder the mount
if you want i can sent a set.
Dick
