Downstairs Dave 37 Posted October 29, 2013 (edited) Removed the N/S wing this evening, looks like its had a replacement headlamp ring fitted in the past. A post panel is in pretty good shape only a couple of tiny holes at the top, not bad when you consider these realy suffer from the evil weevil.:rolleyes: Strut top is a different matter though, I swear more damage was done years ago when repair panels seemed to be brazed in, then the rot realy got going. I have a pair of Mk2 strut top cut outs so I will use the pan and reinforcing top sections. and for location I will make a pair of jigs that will use the steering box/idler arm mounting holes. :thumbdown: Edited October 29, 2013 by Downstairs Dave Quote Share this post Link to post Share on other sites
Ford1975 2 Posted October 30, 2013 Top quality work Dave great attention to detail that is going to be a cracking car when finished.. :thumbup: Just out of curiosity what do you treat any rust/scabs with?? And for making the tooling for the repair panel :thumbup: :thumbup: Quote Share this post Link to post Share on other sites
Downstairs Dave 37 Posted November 1, 2013 (edited) Welded on the bonnet prop bracket today......Many thanks 63tina :thumbup: Shall be doing a bit more tomorrow :rolleyes: Edited November 1, 2013 by Downstairs Dave Quote Share this post Link to post Share on other sites
Downstairs Dave 37 Posted November 1, 2013 Top quality work Dave great attention to detail that is going to be a cracking car when finished.. :thumbup: Just out of curiosity what do you treat any rust/scabs with?? And for making the tooling for the repair panel :thumbup: :thumbup: I use a strip and clean wheel and a hand held sand blaster. Many thanks for your kind remarks Ford1975 :thumbup: Quote Share this post Link to post Share on other sites
the-ford-cortina.com 225 Posted November 1, 2013 Very pleased with the spring mounts and the front chassis leg to front panel, no rust at all, this is definitely due to the car being Ziebart rust proofed when new. if this was done to all the cars would there be more Mk1s left? who knows. The Mk2 Super estate we had was also undersealed from new and is probably still ( havnt seen or heard about it for a few months ) just as good as yours underneath - it was definately money well spent for both of them :winner: Quote Share this post Link to post Share on other sites
Downstairs Dave 37 Posted November 1, 2013 The Mk2 Super estate we had was also undersealed from new and is probably still ( havnt seen or heard about it for a few months ) just as good as yours underneath - it was definately money well spent for both of them :winner: That brings back memories as I had a Fern green Mk2 Super Esate, cost me £250 back in 1979, will see if I can find some photos and check to see if it still exists (doubt it):rolleyes: Quote Share this post Link to post Share on other sites
Downstairs Dave 37 Posted November 2, 2013 (edited) Thought I would offer up the Mazda Diff as the car is upside down.. Have also been busy designing the subframe for the rear suspension, nearly there. How about this for a result, my best mate is an aircraft engineer and these are out of a Boing 777, so rose joints are now sorted for the rear A arms. o/s front wing now removed, have now decided to replace the front lower valance and the two panels below the headlamps as they are full of holes, they looked good before I knocked the filler out :angry2: Edited November 2, 2013 by Downstairs Dave Quote Share this post Link to post Share on other sites
Ale06 7 Posted November 2, 2013 What a nice work. Congratulations and thanks for sharing it with us. Quote Share this post Link to post Share on other sites
Downstairs Dave 37 Posted November 7, 2013 Spent a couple of hours on the car tonight, repaired the bottom of the A panel and end of the sill.. Quote Share this post Link to post Share on other sites
Ford1975 2 Posted November 8, 2013 Real tidy workmanship Dave first class job, NO hidden that'll do bits on that car :thumbup: :thumbup: Quote Share this post Link to post Share on other sites
Downstairs Dave 37 Posted November 10, 2013 passenger side jacking point welded in and also repaired part of the floor and inner sill. Slowly getting there, not that exciting at the moment but I'm starting to see the light at the end of the tunnel. Quote Share this post Link to post Share on other sites
cortina-city 140 Posted November 10, 2013 its looking real clean and solid, metal looks better than on the mk3s, wonder if its a little thicker, that chassis looks good and i like those boing 777 rose joints! Quote Share this post Link to post Share on other sites
63tina 0 Posted November 10, 2013 Welded on the bonnet prop bracket today......Many thanks 63tina :thumbup: Shall be doing a bit more tomorrow :rolleyes: Great fabrication, and metal work Dave, and as for the bonnet prop bracket. no problem mate Quote Share this post Link to post Share on other sites
a1topdog 4 Posted November 11, 2013 Dave - regarding the radius bottoms on the front jacking points - I'd imagine these will be squashed all out of shape the first time you use them to jack the car up. Who supplied your ones? I used the ones from the MK1 owners club and they were the correct shape and made from very thick metal. I think you should change the ones you have before its too late !!! Great project. Keep up the good work. Quote Share this post Link to post Share on other sites
Steve 5 Posted November 11, 2013 I was thinking they look really thin,Perhaps reinforce the jacking strip? Quote Share this post Link to post Share on other sites
