westie289 0 Posted December 4, 2013 Hi, got Another problem to add to the list lol, was driving home from work yesterday and the fuel gauge and heater gauge maxed right out and after a couple of minutes it went back down to normal, it's done it a couple of times since. I am absolutely rubbish with anything electrical, so any advice on where to start would be great :D thanks Charley Quote Share this post Link to post Share on other sites
V6Ghia 37 Posted December 4, 2013 Hi, got Another problem to add to the list lol, was driving home from work yesterday and the fuel gauge and heater gauge maxed right out and after a couple of minutes it went back down to normal, it's done it a couple of times since. I am absolutely rubbish with anything electrical, so any advice on where to start would be great :D thanks Charley This used to be quite a common problem when the car's were under 10 years old and sounds like the voltage regulator which is screwed to the back of the instrument panel. Could be worth checking connections and cleaning, or look for a replacement. Quote Share this post Link to post Share on other sites
steve&lynette 2 Posted December 4, 2013 Bad earth causes most problems on are cars but could be the voltage regulator. :thumbup: Quote Share this post Link to post Share on other sites
deltamal 38 Posted December 4, 2013 Mine was doing that last year, changed the sender on the engine block which cured it, make sure you get the right one though, where the small thread is there is a coloured nylon insert, on my Mk3 it's clear/white colour, it has to match the resistance of the dash gauge. Quote Share this post Link to post Share on other sites
bortaf 92 Posted December 5, 2013 It could be the sender IF the fuel gauge didn't also rise, the only thing that controls both is the voltage regulator on the rear of the clocks ? Quote Share this post Link to post Share on other sites
westie289 0 Posted December 6, 2013 Found a broken earth strap under the bonnet, I'll fix that later on and see what happens, then if not I'll check what you guys have written, thanks for the replys :) Quote Share this post Link to post Share on other sites
Jason 5 Posted December 6, 2013 If the sender wire is earthed out, it should shoot to the top. Hot, full fuel etc.., I'd check for breaks in the wiring and lose wires behind the dashboard shorting against the clocks. Jason. Quote Share this post Link to post Share on other sites
westie289 0 Posted December 16, 2013 Thanks for you replys, broken earth has seemed to cure it :) Quote Share this post Link to post Share on other sites
