cortina-city
MAP READING LAMP
You guys are right. Mine looks like a non Ford add on on my mk5. But it's great practically.
More photos to follow. Am uploading one at a time on mobile phone.
the mk3 (prefacelift one) is only about 3 inch long with a ball type joint, I think its supposed to go next to dash vent in a similar position to the warning light on drivers side.
if you open glove box & feel behind hockey stick trim theres prob a hole.
that´s what i have in memory as well, though i couldn t find a pic of proof! :cheers:
i can post a pic of the accessory brichure Pete if needed, unfortunately it´s only the lamp showing (not installed in a MK3) :cheers:
thats same as mine pete.... more period i think..... bolts to dash so earthed the first L bow it has is the switch as well as position ....there were longer units to...think this one your showing is the shorter of the two......i have a separate switch as well to isolate as they tend to come a bit loose and fall forward,,,so switching itself on.... and not being wired to ignition had a permanent live...battery????? :thumbup:
i reckon thats a wipec one ken, wonder if ford bought them from wipec?
Hans, thanks could you post the piccies?
Gary thanks
evryone so far whos helping on this one.
cheers
keep the info coming i wann see swampy with a quality map reading lamp (ill be going abroad in the car and wanna look the part)
poss as the 1600E spots are by wipac as are the rev lights I think.
here we are Pete, not much i could find by now, but i could have some forgotten stuff somewhere in boxes :headscratch: , don t know whenever i will put some order in my little "archive" :headscratch: :sofa:
(i hope it works, as i can currently only scan at the office)
here is a pic from a general Ford 72/73 accessories brochure:
Anhang.pdf
though it´s mentioned in the price list from the same date :headscratch:
as soon as i can scan stuff at home i might do a compilation of accessory stuff in a better way if wanted! :cheers:
Anhang.pdf
Anhang.pdf
hans, thanks so much, this unit looks like the one you can buy new, with the mount plate attached and about a 3 " unit, so ill go for that one, job done, next job is where did they fit it and dare i dril my dash
