corty 0 Posted June 11, 2014 Hi I'm looking at converting my 2000E to Auto, I have got the box itself but need all the other bits like Auto prop Gearbox X Member, Auto radiator and cooler pipes Selector mechanism and cables Kick down cable and throttle linkage I might have sourced the pedal box and pedal but that is not confirmed so if you have these that would be great Is there anybody on here who has done a reverse conversion got any of these bits that they could sell me or even swap some of the bits for my manual ones? Thanks Paul Quote Share this post Link to post Share on other sites
Danish 294 Posted June 11, 2014 You can manage without changing the pedal box - I swapped by brake pedal for the larger auto one and removed the clutch pedal :thumbup: Quote Share this post Link to post Share on other sites
AndyGhiaMK4 2 Posted June 12, 2014 The cooler pipes are no longer available, even for a sierra, i had mine made up by a hydraulic pipe specialist, hope that helps a little in getting your auto box in your car, also you will need a relay from the inhibitor switch to starter moter to stop the car starting in any of the gears. Quote Share this post Link to post Share on other sites
corty 0 Posted June 12, 2014 You can manage without changing the pedal box - I swapped by brake pedal for the larger auto one and removed the clutch pedal :thumbup: Thanks for the tip :) Quote Share this post Link to post Share on other sites
corty 0 Posted June 12, 2014 The cooler pipes are no longer available, even for a sierra, i had mine made up by a hydraulic pipe specialist, hope that helps a little in getting your auto box in your car, also you will need a relay from the inhibitor switch to starter moter to stop the car starting in any of the gears. Cheers for the info, I must admit I had forgot about the inhibitor. Do the people you used for the pipes need samples or do they know what size and shape is needed as I wint have any for copies? Thanks Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 759 Posted June 12, 2014 you can use original prop.just swap peddle/shaft for auto one. think I've got pedal/shaft & shifter & a cooler. use a separate cooler rather than one in rad. if you've got the ends with short piece of pipe for cooler I've got some auto rubber hose (can use jubilee clips there not high pressure). Quote Share this post Link to post Share on other sites
cortinadale 4 Posted June 13, 2014 If you can get a breaker get the wire for inhibitor switch. Pluhs into loom with no messing around Quote Share this post Link to post Share on other sites
corty 0 Posted June 14, 2014 you can use original prop.just swap peddle/shaft for auto one. think I've got pedal/shaft & shifter & a cooler. use a separate cooler rather than one in rad. if you've got the ends with short piece of pipe for cooler I've got some auto rubber hose (can use jubilee clips there not high pressure). Cheers Craig, can you let me know what you have got abd what you wsnt for them please mate, I have found a auto rad from a supplier so might be sorted there if I can find or get the pipes made up. Quote Share this post Link to post Share on other sites
corty 0 Posted June 14, 2014 If you can get a breaker get the wire for inhibitor switch. Pluhs into loom with no messing around Thanks for the info mate I think finding an auto being broken is going to be as hard as dont know of any :( Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 759 Posted June 15, 2014 seems I've only got complete shifter left. Quote Share this post Link to post Share on other sites
ian27 1 Posted June 16, 2014 I've got a flexi plate and shifter if needed plus complete pedal box Quote Share this post Link to post Share on other sites
steve&lynette 2 Posted June 16, 2014 (edited) Maybe out of the same car the box came out of. you had of me i had of you hes having of me ? ian ? ly 22p ! ha ha,:headscratch: Edited June 16, 2014 by steve&lynette Quote Share this post Link to post Share on other sites
ian27 1 Posted June 21, 2014 Maybe out of the same car the box came out of. you had of me i had of you hes having of me ? ian ? ly 22p ! ha ha,:headscratch: Maybe Steve....but I've broken another E since then so not sure Quote Share this post Link to post Share on other sites
