sheffieldcortinacentre 763 Posted September 28, 2014 the following is a list of parts for all Cortina's mk1-5 & p100.I've tried to group the listing into sectionsbrakes.suspensionetcrather than mk'scan people who know of others please email/pm so that the list can be updated/altered or correct mistakes without additional posts.I hope to add a further post for parts that need only minor mods (ie extra holes/slots etc) to allow fitting.plus another of parts that are usefull for uprateing ie vented discs, heavy duty parts to aid towing etc.brakes....mk1 front drum = Anglia 1200 (123E inc van).front brake shoes as drum + mk1 escort 1300 (-70) inc van, Bedford ha van (71-).mk1 rear drum = Anglia 1200 (123E inc van).mk1 rear shoes as above + Austin allegro (all), Hillman imp (all).mk1 rear shoes est/gt/lotus no other match.mk1 front pads (upto 65) mk1 escort (std models),triumph herald/spitfire (67-81),Vauxhall HB viva/FC victor,volvo 140/160.mk1 front pads (65-67) mk2 Cortina/corsair V4,MGC,vauxhall FD ventora.mk1/2 front disc corsair, capri mk1 (upto 2.0), mk4 zephyr/zodiac.mk2 front pads (upto 68)late mk1 Cortina,corsair V4,mk1 capri,vauxhall victor FD, Austin 1800,triumph TR4/5/6/vitesse 2.0.mk2 front pads (68-) Hillman avengerstd (76-79)GT/tiger (70-76),Vauxhall viva/magnum 1800/2300,FD victor VX4/90/ventora,volvo 343 (76-80) Hyundai pony(79-85),marina/ital. van (78-).mk2 drum (all except lotus) mk3/4/5 (1.3/1.6)capri mk1/2/3 (1.3 only),105E/esort mk1/2van,sierra 1.3/1.6.mk2 shoes mk1 capri (1300 only), triumph dolomite (all except sprint).mk1/2 GT/lotus/1600E shoes capri mk1 1600/2000/corsair V4/mk1 escort mexico/lotus/RS1600, triumph dolomite sprint.mk3/4/5front brake disc mk2 escortfront brake pads std all capris (70-), mk1 escort lotus/mexico/RS 1600/2000,mk2 escort (std models),Hyundai stellar (84-87).heavy duty front pads P100, mk2 Granada 2.8.rear drum 1.3/1.6 all tears capri 1300 (all years),mk1/2 escort all std 1100/1300,sierra 1.3/1.6.rear drum 2.0/2.3 all years capri 1.6/2.0,mk2 escort 1.6-2.0,mk3-6 escort 1.6/diesel vans.brake shoes 1.3/1.6 prefacelift (upto late 73) mk1 escort RS2000,hillman avenger all,sunbeam inc lotus all.brake shoes 1.3/1.6 facelift & mk4/5 unique.brake shoes mk3/4 2.0/2.3 (1.6 GT/GXL/ghia), mk1 consul/Granada,hyundai stellar (84-87).brake shoes mk5 2.0/2.3 (1.6 ghia) unique.brake shoes P100 mk1/2 Granada V6 est.mk3/4/5 brake caliper (std M16)capri all (70-), mk2 escort,mk1 Granada all.mk3/4/5 heavy duty & P100 mk2 Granada 2.0/2.3.mk3/4/5/P100 caliper seals std& hdcapri all,corsair V4,mk1 escort mexico/lotus/RS,mk2 escort all,mk1/2 Cortina GT/lotus/E,mk1/2 Granada all/mk4 zephyr/zodiac,austin1800,mgc,triumph tr 5/6/vitesse.rover P6 2000/2200 (66-)Vauxhall FD ventora/Hyundai stellar.mk3/4 master cyl (2 pipe) uniquemk4/5 master cyl (3pipe) uniqueP100 master cyl uniquemk4/5 3pipe ATE seal kit audi 80(73-77),mk2/3 capri all,mk2 escort (RS1800/2000),P100,saab95/96 (71-76)vw golf/jetta (79-84)polo(75-81)Passat(72-85)scirroco(74-81).rear wheel cyl 1.3/1.6 (upto late73)mk1/2 Granada(upto81),mk3/4 escort/orion(-90non abs),seals also Austin montego est,vauxhall chette,volvo 340.rear wheel cyl 1.3/1.6 (73_) unique, same for seals.rear wheel cyl 2000/2300 all,mk3 escort/orion(XR/RS/D),KA MK1,hyundai stellar (84-87)seals also mk2/3 capri all,hyundai pony(82-85),montego saloon.brake hose front prefacelift only, cradle to body (short one)mk1/2 Granada.brake hose front facelift/P100 ,mk1 Granada,hyundai stellar (84-87).mk3/4 handbrake cable (have adjuster nuts)mk5 handbrake cable (has plastic adjuster wheel) both types swapablerear all (except P100) capri all (front),mk2 escort all (front),jaguar XJ6/12 (74-) all (front),TR7 (front).P100 handbrake cable front part fits mk3, rear part is unique.P100 rear wheel cyl/seals/hose unique._______________________________________________________________________suspension & steeringmk1 outer track rod (sided) corsair.mk1 steering idler arm ohv enged corsair (bush consul classic/capri).mk1 steering arm corsair all.mk2 all above are unique ???mk3/4/5/P100upper & lower ball joints are uniquemk3/4/5/P100 track rod ends mk1/2 Granada,mk2 escort (escept RS 1800/2000).mk3/4/5/P100 sterring rack unique,mk3 steering shaft (preface lift) unique.mk3(facelift)/4/5/P100 (manual steering) sierra manual steeringmk4/5 pas rack/shaft 2 versions (only swappable as a pair)mk3/4/5/P100 steering shaft rubber coupling (all70/80's rwd fords)mk3 steering column pre & post facelift unique.mk4/5/P100 steering column same.manual rack boot capri all,volvo 240/260.pas rack boot iron rack boot as above, alloy rack unique.mk1 front wheel bearing (drum version) Anglia 105E.mk1 rear wheel bearing Anglia 105E,corsair,consul classic/capri.mk1 front wheelbearing (disc version)/ mk2 capri(all),classic/corsair,mk1/2 escort RS,mk3/4 zephyr/zodiac,reliant scimitar (66-71).mk2 rear wheel bearing Anglia 105E(1200)/van,mk1 capri all,mk2/3 capri 1.3/1.6, mk1/2 escort all.mk3/4/5 front wheel bearing mk2 escort (except RS1800/2000).mk3/4/5 koln axle (1.3/1.6) unique.mk3/4/5 atlas axle (2.0/2.3) capri 2.8/3.0.mk3/4/5 stub axle samemk3/4/5 hub sameP100 front wheel bearing (mk2 Granada) mk3/4/5 outer, Granada inner.P100 rear wheel bearing unique.prop shaft universal joint.2 sizes are used across all models, small type is also marina/ital,all vivas/chevette,FD/FE victor,capri 1.3/2.0.larger type capri & Granada.mk3/4/5 rubber doughnuts 6 bolt type 2.0/2.3 all 2.0-3.0 fords (the Mt 75 version is slightly thinner & requires packing washers.mk5 3 bolt bonded doughnut is unique.all models centre bearing & rubber is used acroos the rwd ford range (only mounting cage is unique to Cortina's).mk1 tca bush inner corsair, outer bush corsair,mk1 rear leaf spring front bush mk1 escort van.mk1 rear leaf spring shackle bush Anglia 105E,mk1 escort/capri.mk2 tca bush inner Anglia 105E,corsair,consul classic,mk1/2 escort.mk2 tca bush outer mk1/2 escort, capri all.mk3 (oval) front tie bar bush mk1 Granada.mk3/4/5/P100 (round) front tiebar bush mk2 Granada.mk3 (small prefacelift) cradle to body bush mk1 Granadamk3 (large facelift) 4/5/P100 triangular cradle to body bush mk2 Granada.mk3/4/5/P100 front roll bar bush unique (vary for bar thickness.mk3/4/5/P100 roll bar drop link bush mk1/2 Granadamk3/4/5/P100 lower arm inner bush mk1/2 Granadamk3/4/5/P100 upper wishbone bush uniquemk3/4/5 rear upper arm to body bush all samemk3/4/5 rear upper arm to diff bush all samemk3/4/5 rear lower arm to axle bush all samemk3/4/5 rear LOWER ARM TO BODY BUSH (PREFACEFIFT IS DIFFERENT SIZE) TO POST FACELIFT ONWARDS, CHECK BY MEASUREING AS EITHER COULD BE FITTED BY NOW.rear rollbar bushes all same but vary by thickness of bar.P100 leaf spring bush same as sierra P100 as is spring (only rear suspension part they share).mk3/4/5 front shocker mk1/2 Granada. (will fit P100 with mod to top tube)mk3/4/5 rear shocker fwd escort van rear (some makes are same length).mk3/4/5/P100 frt springs all the same size rates vary.mk3/4 rear springs are the same.mk5 rear springs have a softer top coil (but will swap with above) various rates.P100 rear shockers unique.________________________________________________________________________engine & gear boxmk1 eng mounting rubbers mk2 pre crossflow.mk2 eng mounting rubber unique.mk3/4/5/P100 eng mounting rubber mk1/2 Granada, mk2 transit, range rover classic.mk3/4/5/P100 gear box rubber mount (manual/auto are the same) all capri,sierra,mk1/2/3 Granada,mk2 escort.1600 ohc cambelt 2.0 alfa romeo (73-78)2000 ohc cambelt fiat regatta 1.6 (84-90),Mitsubishi 1.6/2.0 (non turbo 73-82).ohc fuel pump cologne V4/6, cvh ford.ohv fuel pump (ford fwd ohv eng)ohv/cologne V6 alternator cvh /ohv (fwd).ohc alternator Essex V4/6._____________________________________________________________________________________ignition systemm1/2coil 70's alfa sud,bmw 4cyl (70's),fiat (70's-80's)lada (rwd),landrover (-85), BL (-85)relian, Volvo 4cyl (080)Hillman (080).points (lucas) land rover(-71),Austin "A" series (-74).condenser (lucas) jag 6 cyl (-75), land rover (-85), bl (-75).rotor arm (lucas)land rover (-85), bl (-75).cap (lucas) "A/B" series (55-63),Vauxhall 1500(53-59), land rover(64-71).mk2-5/P100 (points type ) coil motorcraft or bosch all ford of period.mk3/4/5 (motorcraft) points ohvmk3/4/5/P100 (motorcraft) points ohc/Essex V4/6/small block V8mk3/4/5/P100 (motorcraft)condenser ohv/ohc/essexV4/6/small block V8.mk3/4/5/P100 (motorcraft) rotor arm ohv/ohc/Essex V4/6.mk3/4/5/P100 (motorcraft) cap ohv/ohc/Essex V4mk4/5 (bosch) points ohc/cologne V4/6,alfa sud/twincam (70-82),bmw 4/6 cyl(70's),merc 4/6/8 cyl (70's),vw flat4(70's)Volvo 4cyl(70-82).mk4/5 (bosch) ohc/cologne V4/6mk4/5 (bosch) rotor arm (inc elec ign) bmw 1602-2002 4cyl,opel 4cyl (70's),cologne V6 ,opel 6cyl (70;s).mk4/5 (bosch) cap 4cyl cap alfa romeo sud/twincam (70-82),bmw 3/4/5 series(75-80),ford (-90),lancia twincam(73-85),merc 200(70's),saab(73-),Vauxhall chevette(78-84),vw 4cyl sohc (75-85),Volvo(74-90).mk4/5 (bosch) V6 cologne cap bmw (75-86),opel (72-88).bosch elec ign coil (ford-90's)spark plugs ohv/cologne V6 Essex V4/6,bl "A/B" series,hillman avenger/hunter, vauxnall 1056-1256 ohv.ohc small block ford V8___________________________________________________________________________________filtersoil filterohv cartridge reliant.spin on bl "A/B/E" series,vauxhall 1.6-2.3 slant 4/ 1.6-1.9 cam in head (67-80).ohc Essex V4/6/cologne V4/6, fiat/lancia twincam(72-85),opel str6 (70's) Hillman avenger/hunter (66-80),Volvo (60-2000).air filterpre crossflow (std) comer (PB van),Hillman avenger (71-76)/hunter (66-72),Vauxhall victor F/FB/FC (62-67)/Viva Ha/B(62-70).mk1/2 1.5 GT capri 3.0/mk1 Granada 2.5/3.0,corsair 1.5/2.0 GT,mk4 zephyr/zodiac,mk1 transit all,vauxhall victor FD/FE.mk1 lotus jaguar E type 6cyl,merc 200 (68-77).mk2 std mk3 ohv (-73).mk2 1600GT/E skoda favorit 136(89-).mk2 lotus mk1 escort (potus),opel record di(74-77),TR5/6 inj/2500pi(68-77),saab93/94/95(59-77).mk3/4/5 ohc , mk3 escort/orion (with vv carb)mk3/4/5 (with weber twin choke) mk1 escort RS2000, mk1/2 Granada 2.0 ohc.mk4/5 2.3 mk2 Granada V6, sierra 2.3.________________________________________________________________________panelsm3/4/5/p100floor pans sameboot floors samechassis rail (under floor) samechassis rail (under boot floor) same (est 3inch longer)inner/outer sills all same (P100)shorter)saloon inner/outer rear lower corners all sameest inner/outer rear lower corners sameest inner/outer rear valance sameest upper rear valance sameest rear slam panel sameest tailgate same (only handle holes differ (mk4/5 same)saloon inner rear valance same.mk3 saloon outer rear valance unique.mk4/5 saloon outer valance sameA&B posts samekick panels samemk3 front scuttle same.mk4/5/P100 front scuttle same,mk4/5 rear scuttle same.mk4/5 bonnet boot samemk3 4dr/est front doors same,rear door skins same.mk4 4dr/est/mk5 est doors same.(P100 small vent frt doors)mk5 4 dr front doors (P100 full B pillar front doors) samemk5 sloon rear doors unique.mk4/5 door skins all same.mk3/4/5 wing mounting rails same.mk4/5 front upper valance samemk4/5 lower front valance same shape (but have different cutouts)mk4/5 inner front valance samemk4/5 est roof & rear wings same.mk4/5 saloon rear wings (only differ in rear pillar & light mount).mk4/5 sunroof samemk3/4/5 wiper panel/motorpanel/heaterbox are all same.mk3(facelift)4/5/P100 dash structure are same (mk5/P100 heater aperture slightly different)mk4/5 headlamps same____________________________________________________________________________miscsteering wheelsmk1/2 mk1 escort.anglia105E,corsair,capri.mk3/4/5/P100, mk1/2 Granada,mk2 escort,mk1golf/polosteering column mk4/5/P100 samewheels studs mk1/2,mk1 escort/mk1 capri,corsair,mk4zephyr/zodiacmk3/4/5/P100, mk1/2 Granada/mk2 escort/mk2/3 capri, post 80 fordswheels mk1-5 4X 108 Hillman,puegeot/citreon,saab (900-),Porsche 928, American 4 stud ford.P100, rover P5/6SD1,cherokee (2000-)mk3(facelift)/4/5/P100 ind stalk samemk3/4/5 saloon boot lock same also mk2 escort/mk1 Granada.mk4/5 door handles same also mk1/fiesta/mk2 Granada. ------------------------------------------------------------------------------------------------------------------------------------- Front windscreenMk3/4 all,mk5 estate only,P100 (with small B pillar vent) use the same one Inc rubber.mk5 saloon only (2/4dr) the uk cars have a different size glass/rubber to those built on the continent (the opening is the same size/shape & so are swappable as a pair)This screen fits the P100 with full B pillar vents.Mk3/4/5 (2/4dr) saloons all have a unique rear screen & rubber. (But each Mk uses same on 2/4dr).Mk3/4/5 estates use the same tailgate glass/rubber.Side glassMk3/4 (4dr/estate) use the same front door glass).Mk3/4 2dr use the same front door glass.Mk3 4dr saloon rear door glass is unique,Mk3 estate rear door glass is unique.Mk3 2dr rear side glass is uniqueMk3 estate load area side glass unique.Mk4 saloon/estate & MK5 estate rear door glass are the same,Mk4/5 estate load area side glass is the same.Mk4 2dr rear side glass unique.Mk5 (2/4dr) saloon glass all unique (4dr front door glass fits p100 with full B pillar vents )Mk5 estate glass as mk4 except frt door glass unique (fits p100 with small B pillar vents )P100 rear screen fits all year's (also fits mk3/4 bakkie too). Share this post Link to post Share on other sites
