Lobby
MK3 Restoration
Hi all, after a 2 month wait I've just got my refurbished brake servo back. Not sure if I'll have time to get it fitted and bled this weekend but  once I do I'll let you know how it performs!  Hopefully it'll at least stop now :)
May I ask who refurbished the servo, and the cost?
Cheers
Cheers
Hi, £228 Inc postage from http://jlspares.com/
Thanks for that, I’ll investigate getting mine done.
Hi all, just after a bit of advice.
A new master cylinder was fitted  to my car last year (not by me) and I think it is a land Rover type but the reservoir clashed with the vacuum connector on the brake servo.  Now I'm putting it back together I'm trying avoid having the same problem. Here is a photo of the original (dead) master cylinder and the new one, you can see why there is now a clearance issue.
I've relieved the edge of the reservoir as much as I can and have also fitted a couple of washers between the servo and the master cylinder to gain a bit of room. Am I right in thinking that the washers won't be a problem once the system is up to pressure and the servo rod is against the plunger in the master cylinder?
Here is a comparison of the original and Land Rover master cylinders fitted and the clearance issue is easy to see.
Yep landy one, won't be a problem you could swap fitting for a right angle one, spin servo 180* so it's at bottom.
Cheers, I was wondering if it would be ok to turn the servo upside down, I guess it makes no difference to how it works.
No it doesn't matter.
