XR6 3 Posted January 28, 2015 Can anybody tell me the stud pattern for a P100 ? Quote Share this post Link to post Share on other sites
consul315 180 Posted January 28, 2015 (edited) PCD is 5x5" or 5x127mm, same as Rover P5, P6, SD1 etc and older Austins Landcrab etc., Vauxhall Cresta/Velox/Viscount (PA to PC) and possibly some others :cheers: Edited January 28, 2015 by consul315 Quote Share this post Link to post Share on other sites
XR6 3 Posted January 28, 2015 PCD is 5x5" or 5x127mm, same as Rover P6, SD1 etc and older Austins Landcrab etc., Vauxhall Cresta/Velox/Viscount (PA to PC) and possibly some others :cheers: I've seen some wheels that will fit 5x127 whats the 127 bit been ? is it the distance between the holes .Also whats the offset ? Quote Share this post Link to post Share on other sites
consul315 180 Posted January 28, 2015 (edited) I've seen some wheels that will fit 5x127 whats the 127 bit been ? is it the distance between the holes .Also whats the offset ? it´s only the circle "around" the holes (5 stud) and has nothing to do with the offset. see here: http://www.raceandroad.com/technical-help/stud-pattern-pcd.html http://www.raceandroad.com/technical-help/alloy-wheel-offset.html as far as i know a straight fit are SD1 (Vitesse) alloy wheels, as should Dunlop (D4??) (combined steel alloy) and Cosmic MK2, if i remember correct :headscratch: i can do pics of the Vitesse and Dunlops asap if needed, and here are the Cosmics: http://www.buysellcortina.co.uk/forums/index.php?/topic/36874-for-your-wheels-only-my-latest-acquistion/page__p__330064__hl__%2Bfor+%2Byour+%2Bwheels+%2Bonly__fromsearch__1#entry330064 Edited January 28, 2015 by consul315 Quote Share this post Link to post Share on other sites
the-ford-cortina.com 226 Posted January 29, 2015 (edited) Presume we are talking Cortina P100 as Sierra shape is a different PCD again Hans list is correct , plus some American cars too P100 WITH ROVER P5 ROSTYLES ( click on the thumbnail at bottom of page )- DONT KNOW WHO THEM CHAPS IN THE BACKGROUND ARE :ninja: Edited January 29, 2015 by the-ford-cortina.com Quote Share this post Link to post Share on other sites
Danish 294 Posted January 29, 2015 That's the first time I've thought those aftermarket spot-lamp grilles look good. :thumbup: Quote Share this post Link to post Share on other sites
bortaf 96 Posted January 29, 2015 Presume we are talking Cortina P100 as Sierra shape is a different PCD again Hans list is correct , plus some American cars too P100 WITH ROVER P5 ROSTYLES ( click on the thumbnail at bottom of page )- DONT KNOW WHO THEM CHAPS IN THE BACKGROUND ARE :ninja: Very dodgy looking IMHO :sofa: SD1 wheels look good on em i think :afro: Quote Share this post Link to post Share on other sites
XR6 3 Posted January 29, 2015 it´s only the circle "around" the holes (5 stud) and has nothing to do with the offset. see here: http://www.raceandroad.com/technical-help/stud-pattern-pcd.html http://www.raceandroad.com/technical-help/alloy-wheel-offset.html as far as i know a straight fit are SD1 (Vitesse) alloy wheels, as should Dunlop (D4??) (combined steel alloy) and Cosmic MK2, if i remember correct :headscratch: i can do pics of the Vitesse and Dunlops asap if needed, and here are the Cosmics: http://www.buysellcortina.co.uk/forums/index.php?/topic/36874-for-your-wheels-only-my-latest-acquistion/page__p__330064__hl__%2Bfor+%2Byour+%2Bwheels+%2Bonly__fromsearch__1#entry330064 thanks Hans :thumbup: so what is the PCD for a p100 cortina ? Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 767 Posted January 29, 2015 5in/127mm same as rover P5/6/SD1, Sherpa/pilot, Cherokee rounded front end (2000ish onwards). yank fords are same as Granada at 4.5 in/114mm sierra P100 is same as transit 6.4in/160mm Quote Share this post Link to post Share on other sites
consul315 180 Posted January 30, 2015 thanks Hans :thumbup: so what is the PCD for a p100 cortina ? as in my post nr:2 :cheers: PCD is 5x5" or 5x127mm, same as Rover P5, P6, SD1 etc and older Austins Landcrab etc., Vauxhall Cresta/Velox/Viscount (PA to PC) and possibly some others :cheers: Quote Share this post Link to post Share on other sites
