JoeyGXL 17 Posted February 26, 2015 My ignition barrel in my mk3 has been playing up for a while, in that when starting it doesnt dis-engage the starter motor automatically, i have to manually twist the key back. And all of a sudden this evening the key just stops on the 2nd stage and will not go any further (to engage the starter) I noticed the steering lock doesnt work now either?? Has anyone had anything similar??? If not does anyone have a replacement? im in kind of a hurry as its booked in for a bit of welding and an MOT on monday and it wont start! :shocking: Share this post Link to post Share on other sites
Danish 294 Posted February 26, 2015 I have a replacement barrel :thumbup: Are there any PFL / Facelift differences? Share this post Link to post Share on other sites
wolfrace 116 Posted February 26, 2015 (edited) No differences Jayne (I think, I have looked at a PFL one and it looked the same as mine) I sold my last spare to a MTOC member. Have you ever removed one before Joe? You need to get the shear pins out and remove the whole lock housing from the column then drill the casting to disengage the lock barrel (there are other methods but you probably need more specialist kit) I can come over on Sunday if you like and help. Edited February 26, 2015 by wolfrace Share this post Link to post Share on other sites
Danish 294 Posted February 26, 2015 Have you ever removed one before Joe? You need to get the shear pins out and remove the whole lock housing from the column then drill the casting to disengage the lock barrel I've done it and I have photos, but probably best not to post them on-line. Share this post Link to post Share on other sites
JoeyGXL 17 Posted February 26, 2015 No differences Jayne (I think, I have looked at a PFL one and it looked the same as mine) I sold my last spare to a MTOC member. Have you ever removed one before Joe? You need to get the shear pins out and remove the whole lock housing from the column then drill the casting to disengage the lock barrel (there are other methods but you probably need more specialist kit) I can come over on Sunday if you like and help. :blink: bummer! No i havent done one before, ah that would be amazing if you wouldnt mind dude!! And Jayne you're a star! I'll hopefully come and get that on saturday eve :superman: You guys rule!!! :thumbup: Share this post Link to post Share on other sites
wolfrace 116 Posted February 26, 2015 It can be a bit of a pig of a job with the column in place, did mine quite quickly. I'll give you a hand bud :thumbup: Deffo no-no putting photos of that on online. :thumbup: Still haven't got tyres for them rims yet man but when I do I'll have a go swapping them at yours. Share this post Link to post Share on other sites
littlenewt2067 33 Posted February 26, 2015 Isn't the spring action provided by the plastic wiring part attached to the wiring? I would take cowling off and undo the two Phillips screws holding it on the end of the barrel and put a flat blade into the plastic part and start the car using that and see if it springs back. It may just be this you need. This would also allow you to try the key in the barrel and turn it to see if that is turning freely and not sticking. I think on really early cars you can't take the barrel out without drilling the housing. On the later mk3,s you can press the tab with the key in the second position to remove barrel Share this post Link to post Share on other sites
wolfrace 116 Posted February 26, 2015 Yhea, the circular switch with two screws on either side? You're right that would be a good place to start, the ignition barrel itself has a small spring loaded bearing which I guess helps it eject the barrel, my thoughts are if that has deteriorated or broken off somehow it potentially could be stopping the key turning. But it could be that you need a new switch Joe and I have a feeling the PFL ones have different connectors to the FL ones as I had a FL one and it was different to the one on my car. Maybe there is a way of ejecting the barrel but I've only seen the drilling method before (on Mtoc) (only a small hole and an allen key needed, can always refill with JB weld) I have seen someone use a 1/4" drill bit and annihilate the monkey metal and the barrel, the same chap who bought my last barrel had a garage destroy his last one in just this way trying to get it out! Is this Maizey or the V8? BTW Share this post Link to post Share on other sites
Danish 294 Posted February 26, 2015 On the later mk3,s you can press the tab with the key in the second position to remove barrel I had to drill mine :( Share this post Link to post Share on other sites
the-ford-cortina.com 226 Posted February 26, 2015 Isn't the spring action provided by the plastic wiring part attached to the wiring? I would take cowling off and undo the two Phillips screws holding it on the end of the barrel and put a flat blade into the plastic part and start the car using that and see if it springs back. It may just be this you need. yes and thhis could mean you can start and run the car -- providing the steering lock doesnt engage Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted February 26, 2015 the full lock assembly can be swapped between pre & facelift but the housing/barrels cannot be mixed. as said the prefacelift needs drilling as said. the switchs are interchangeable but the plugs differ so you must get correct one or re solder you original plug to another swt. theres pre & post mk3 then mk4/5 all have different plugs. so 4 in total. Share this post Link to post Share on other sites
JoeyGXL 17 Posted February 27, 2015 (edited) Thanks for all the useful info chaps and ladies! It is the V8 (K reg - July 1972) and the steering lock has stopped working along with the key stopping so could that mean it is the switch that is FUBAR? :headscratch: I did spray a bit of WD40 into the keyhole to free it up but it hasnt worked. And when pulling the key out it came out covered in a metallic paste which I assume is a load of metal fillings mixing with the WD. :shocking: hmm? bugger! Edited February 27, 2015 by JoeyGXL Share this post Link to post Share on other sites
wolfrace 116 Posted February 27, 2015 The metal in the lock can even be from worn keys. I sometimes found that with old locks you are almost better off leaving them because as soon as they are all clean inside they become more awkward. I would say first thing to try is the ign switch, hopefully it's that. Once that is off if you can see if you can operate the key and steering lock OK. If not and the ign switch works then the barrel could be the issue. I dont know much about locks tbh, just how to get these things off and get them apart. But they can jam or do odd little things for example when pushing in the key mine some times pops in and you have to fish it out to put the key in properly, I've known a few cars that do this over time. Do you have a small metal punch, we'll need one, I have one but need to look for it, I have some metal drill bits here but hopefully we wont need one. If your MOT is on monday and it is the ign switch you'll need to take a photo of yours and find a replacement, I've seen them go for around £10-15 or better borrow the one off maizey as that'll be a pfl and it gives you a chance to source another. Might be worth trying that tonight before going any further? The switch isn't specific to the cut of the key the only difference between them is to the wiring loom that they connect to between early and late models so it should work if your current barrel is not the problem. :thumbup: Share this post Link to post Share on other sites
Danish 294 Posted February 27, 2015 I did spray a bit of WD40 into the keyhole to free it up Next time use graphite powder. :thumbup: If your MOT is on monday and it is the ign switch you'll need to take a photo of yours and find a replacement, Joe has managed to borrow a complete F/L steering column from some kindly forum member :rolleyes: Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted February 27, 2015 that sounds like barrel/housing problem rather than switch. Share this post Link to post Share on other sites
