cortina-city
My Latest project 1971 4 Door GXL
Are you doing it entirely with electronics or using a micro-processor? At some point I'll have to build a stand-alone controller for my supercharger, but most likely I'll do it in software with a PIC processor.
clock pulse on a 555 Jayne then fed into 4017 decade counter but only using 6 digits, first 4 on colour drive via some 2n222s and some relay outputs used to. its part of the arm disarm sequence too. also feeding the low fuel/high temp/oil/frost into the quad colour master lamp
considered pic chip or arduino, however could nto at this point justify the time investment on learning the c+ coding or the pic prog procedure.
i guess not quite enough complexity in my setup to justify the potential of an arduino. i did conside running a total system on it but i felt i was better off with individual modules in this case.
the 4017 is pretty bulletproof 555 etc
the car will has the ford harness 'drop in' on top of the sublooms, by carefully noting the connection points i can fault find in future if necassary
I love the idea of a PIC chip though and arduino. not sure about raspberry pie have you ever experimented with the raspberry unit / arduino
its somethign ill be looking at in future
its a bit labourious verobaording in and with my eyes these days a lot harder than the college days!
Nice feeling getting the clock pulse up and stepping the 4017 though!
just gotta link in to the warning lamp now so that the 12v outs from the warnign lamps are seperated from the 4017 circuit,i may optocouple them yet not sure, rewason to isolate is voltage spikes etc
Respect for doing it in hardware.
Yes, I've used PIC and Raspberry Pi, but then I've a lot of C/C++ experience.
1970's. Before cars got all the electronics and got complicated 😂 It's all gobbledygook to me but I love it 👍🏼👌
completed the master warning lamp:
works as follows.
Iginiton on, self test cyles all colours
low fuel, slow blink every 10 seconds, yellow lamp
frost black ice -2C green, slow blink every ten secs
high engine temp, fast flash, orange every 5 secs
low oil, red, fast flash every five secs
incoming call/bluetooth hook up, blue flash every ten secs until call hangs.
sidelamps on, all lamps if on, dim to half brightness
car ready to roll out to soda
thanks tony, what colour you want? ill build one and bring yat
fit to sidelight feed as its dash out to fit the sensor switch or devise your own system of switch.
wow thanks rich ill take a look
Thanks for the kind offer Pete , :thumbup: But you have enough to do :wife:
;) See you at the weekend
o, what colour would you have chosen Tony? White, green?
stickerz too, ill see ya there
almost finished the heater control panel illumination
this pic does not show the final result, im just mocking it up, i have to fit the final colour filters and logos but first i needed to get the smt leds sitting right before i finish the colour layers
i dont like non illuminated heater controls so i built a system to light it all up
when sidelights are off and in normal daylight the heater decal is exact same as orginal, you cannot tell its been changed
so it looks totally stock orginal
just need to add the blue filter to the hot-cold slider
then drop the voltage so its not too bright, then im good to go.
Looks awesome mate,
I think i might have to send one of my cars to your place for a refurb
Looks awesome mate,
thanks andy ill post a proper pic when its done
the decal is not stuck down on the picture and its not got the colours on, so it will look the business
send a car..................not sure when though lol
Awesome mate i will need to get a second mortgage
most of the mods ive done on the cheap...its just the time aspect
good luck thurs andy
Whether it's on the cheap or expensive mate they look fantastic.
So now you have done it once it should take half the labour time lol.
Thanks mate i've got everything crossed for thursday
hope youre on the mend.
Been on the wiring harness Andy
wiring bay harness, repaired fords dangerous loom, stripped it all back and fitted the fuse where it should be so the darn thing dont burn on quad lamps
i ended up stripping the bay loom and rebuilding, added a decent gauge cable from alternator to battery and made sure the volt drop wires for the ammeter were in right place for an acurate reading, rewrired the poor wires to the heater blower, they cant handle the current so blower motor runs 10% under with the voltage drop on the tin gauge cable. a thicker cable sorted it.
tested out ok. would still like a beefier motor though on the blower.
next job, ring dave.com to collect shell and take to soda city.
