cortina-city
My Latest project 1971 4 Door GXL
rebuilt steering wheel
2 pack finish
rechromed centre trim panel
repainted
refurbed wood panel
rechromed centre clocks
built the ford dealers sticker for rear window
I love the dealer sticker !!
The chrome is looking lovely Pete
vin tags next.
just writing a programme to analyse build tags
data so far:
BFERT HN ---
V - W - G -- NA
SAP M GXL VB XXXBFERT B (AUTO) HN A - --
VFW GM -- NA --
OXX B GXL VB XXXX
BFERT 1L
YEL (COL) 1600 = l
h=ohc
n=2000
bfert factory
sap oxx yel taw colours
B = auto
n decade
need more build tags im using 6 at moment with all different specs to find what changes etc
idea is to build a build tag to suit my car with its new changes
ie 2000 maize auto
nearly there
just a note on 2 pack
YOU MUST MUST wear a mask
I use a 3m twin cartdridge face mask
even your eyeballs must be covered so full face mask needed!
for the plastics I used kolorbond matched with a swatch from rubys paint scheme
for the centre pod unit I had to use 2 pack paint, its glossier than the kolorbond, looking back I should have asked to mix it with a matting agent really
you have to use 2 pack when painting over the chrome you see.
kolorbond wont key onto the chrome as good as 2 pack
and te centre pd is entirely covered in chrome and you overpaint the area leaving what parts you want chrome masked off.
so , if I did it again I would put matting agent into the 2 pack, I hope the gloss will dull slightly, its fresh paint on the pic.
Danish will prob wanna see the algorithm
well miss its written in BASIC
just using an online editor
10 LET A = "FIRST TAG SECTION"
20 LET B$ = " CAR ORGINATOR"
30 PRINT A ; B$
40 PRINT A$ ;
ETC
Loving the Ruby stuff Pete, its all good practice for the next one on the line :winner:
Rear end of mine feels nice and tight but not hard, i went 50/50 orange and std Ford with the rear end bushes also a 16mm anti-roll bar.
I think a pair of these cup covers also make a difference to soak up a little bit of vibration i went for the 16 mm ones as my arms are the same as yours.
However anyone with the early arms where the spring bolts to it can probably only use the 6.5 mm ones.
CUP COVERS LINK
I am away for a couple of days but on my return i shall PM you pics of a couple of build plates and what car they are off for your collection. :)
looking good pete when did ruby red first appear as my mk2 is the same coulour
SAM_2884_zpssrr7tuio.jpg my export Cortina 1600 e steering wheel
Centre console looks good, I'd never even noticed the bezels having chrome around them before, I guess in most this has just worn off.
Would be good if someone finally decifered the build plate. Esp for those who need replacements during rebuilds as it's a common rot area. Vin saved mostly through being ally.
Edited by wolfrace
THANKS LADS,
Richard, ill keep decoding vin
so far ive found it describes, year, engine, box
much like main tag
ive crossed referenced with other ford stuff from 70s
Marky thanks, yes ill get those rubbers
John, Ruby was around at least in 1970 its showing in my trim catalogue on zephyr too
thanks for replies lads
ie 2000 maize auto
nearly there
As always one step beyond, cracking idea for the over obsessed haha.
The whole build is going to be another big notch in the bed post. 👍🏼
CUP COVERS LINK
thats the other ones i was trying to remember ..superflex... i used them on rear springs {top hats} and lower arms...where the rear anti roll bar straps....i hear there the best pushes... i intend to go 50/50 on ojo this year...as mark....
pete ..you have done an amazing job on matching colours...nice and crisp..sharp...and that chrome... :icecream: ..well done chap :thumbup:
Edited by nogE
I thought you might :rofl:
