E-man 0 Posted September 20, 2015 Apologies if this info is in here already, I have searched but didn't find anything . The 4 speed gearbox in my 1600E series 2 has started to make a noise. Slave cylinder is also acting up even after a rebuild. I have a type 9 5 speed already and was planning on taking the plunge. Can anyone help with all that would be involved. Driveshaft, speedo, bell housing, pressure plate, clutch. Hydraulic or cable clutch, will I need to change pedal box. I do know I will need to adjust the gear lever position. All help appreciated Thanks Quote Share this post Link to post Share on other sites
austwombat 4 Posted September 20, 2015 (edited) unfortunately the search doesn't like short words less than 2 chars so can't search on type 9, but if you search on type and speed and mk2 you'll get lots of hits returned. Edited September 20, 2015 by austwombat Quote Share this post Link to post Share on other sites
E-man 0 Posted September 20, 2015 unfortunately the search doesn't like short words less than 2 chars so can't search on type 9, but if you search on type and speed and mk2 you'll get lots of hits returned. Found the posts, thanks for the help 😊 Quote Share this post Link to post Share on other sites
