greensleaves 0 Posted December 31, 2015 A National (TIBBS) clutch.? I read about national clutch issues on another post. It's a possibility but it's not from national clutches and I bought it of that eBay about 8 years ago so think it might be ok. Share this post Link to post Share on other sites
greensleaves 0 Posted December 31, 2015 It's always best to check the simple things first, and not jump to conclusions. I would start with a compression test, as it is possible that a piston is damaged. If that's ok, I would drain the oil, to see if any metal bits were in the sump, as it's quite possible that a big end bearing is failing. Hope this helps. Pete. Hmm yes, I wouldn't know how to do a compression test but would like to find out how. Thinking about it now I've always suspected that there's been something wrong with cylinder number 4 because the spark plug is sometimes a bit oily. For a while now I've been wanting to take the head off and de Coke but it's just time... When I do I can inspect things then. I suspect I'll end up taking the whole engine out and either refurbing it or replacing it. I have a 205 block which I bored out to 2.1 just sitting waiting so might put that in.... Time though is my enemy. Share this post Link to post Share on other sites
TIB3300 455 Posted January 3, 2016 Bit far just for a cortina chinwag really, especially if I'm going to poop round (yes I saw your pre edit haha!) thank you for the offer though I appreciate it. Where abouts are you anyway? If I'm out and about in the area one day I could let you know. pm ed :thumbup: Share this post Link to post Share on other sites
