Deano66
My mk3 Estate.
On 6/8/2023 at 9:42 PM, 107me said:
Any update Deano, hope you get your mojo Back soon as I love this thread, you’ve done a great job. Would be great to see some update as you’ve come so far 👍
Hi mate,I've been doing a bits,but nothing major,will be back on it soon.
Hi guys & girls,I finally managed to get back onto my Cortina today,
I haven't been doing much,I lost a bit of motivation as I couldn't figure out why the nearside front subframe mounting wouldn't line up.
It was about 1 inch too low,I thought chassis leg was bent,but after checking & measuring & checking again,they are ok, 1-2mm
difference that's all. In the end I put some threaded bar through the bushes,then I found the fault. When i bought the chassis legs all
them years ago,I got a odd pair,the nearside front mounting is a different shape & lower than the offside. I never even thought to check, I never knew there were different ones.
SAM-2079
This is the offside mount,note the shape under the bush & the distance between the top of the bush & the oval cut outs.
SAM-2080
This is the nearside mount.
SAM-2081
Now it's time to cut it out & refit it.
Nice one think most of us who go as far as this have moments where you things aren't going right and all the work you put in seams waisted ,step away and find the problem all ways a good  boost in motivation
as for the panel I laugh when someone tells me there all the same bits in a Cortina and it's far from that
I never knew they were different,I always thought they were the same,which is why i never checked them. Just goes to show,you need to check everything you buy.
I cut the mount out today & raised it 1 inch,the subframe fits now :biggrin:
SAM-2084
SAM-2085
SAM-2088
SAM-2090
SAM-2091
  • Thanks 1
On a roll now
22 hours ago, J2S said:
On a roll now
Getting back there slowly :biggrin:
Although I haven't touched my Cortina for a long time,I still lookout for Cortina stuff. I have just got this newspaper supplement off ebay,I haven't seen one before.
  • Like 3
2 hours ago, johnny boy said:
Nice find
That's what I thought johnny boy, I haven't seen any more.
Well I haven't touched my Cortina for a long time,too long to be honest. I have started looking at the front end to see what I need. The front end that I got many years ago has been 'restored' at some time,but needs doing again,nothing seems to fit correctly & both sides are different.
If anyone has any pics of a stripped,unmolested front end I can use for reference that would be great,
Cheers.
Originally the upper frt valance had a recess for the piece of front wing to "sit in flush"  ,you could only get the full panel from ford to repair it .
Pattern ends were available ( I've some) but they don't have the recess they stretch to the bumper cut out.
I'll try get a pic tomorrow of one.
Thanks Craig, that was one of my concerns,how the wing fitted to the upper panel,my original front was too rotten & this one hasn't been repaired properly,I did wonder if it should be recessed.
I've not done a lot lately,a few little bits,but i keep putting this job off,well,I decided to get on with it. I know I could buy a new cross member,but it is far too much fun to make one. I used good old cereal boxes for the template & I have used the side panel of a Transit,which was given to me by our bodyshop. This is it so far.
Nowt wrong with that ,nice bit of fab work.
