Pete-H
K & N Airfilter
I'm after a K & N Air filter suitable for a Webber 32 Dif 4 Carb?
wonder if same as webber cortina carb>
im not sure of the specs pete?
i have one spare
no idea of value
it came with swampy
i have one spare
no idea of value
it came with swampy
Ok Pete thank you.
This is the Carb the hole centres are measured diagonaly 110mm and 52mm
Now I have fitted the Alternator I cannot fit the original Fram air filter that came with the car.
Have unit for 32/36......again..Not sure..check when back home. .Monday. .
The bolt holes sometimes match but the hole for it to fit over can be a different shape - you can cut them to fit
Very true Dave.
Thank you NogE
looks different to mine pete :-(
Can you pm me a pic please Pete?
Sorry to butt-in and look like a not it all but isn't that carb a 32DFM? If it is they are fitted to mk1 escort 1300gt's, and 1600e's. That might help you track one down?
Do you know it's been a long time since iv seen one of them..and thought the same..looks like the 1600E twin choke. .
looks to be the same fitting as 1600E,i think the 4 mounting holes are the same on most webber carbs,
Here is a close up of the carbs ID markings.
NogE Please let me know what you have in the way of a K&N air filter tomorrow?
Edited by Pete-H
