TIB3300 389 Posted May 20, 2016 (edited) Hello peeps I remember this from years ago, my car leans to the drivers side when looked at front the rear. I did swap the springs round to see if that helped ,nope! Still does it .So I have a few plans Fit one estate rear spring on the drivers side Fit gas assisted shocks Fit one of those rubber spring assisters Anyone solved this on there own car ? Edited May 20, 2016 by TIB3300 Quote Share this post Link to post Share on other sites
do it sideways 41 Posted May 20, 2016 This is going to sound crazy, but on a car that came in years ago someone had fitted new balljoints to one side and tightened up the top and bottom bush bolts with the suspension hanging down, not saying that this is your problem but one of the list of things that," could "make it lean or sit higher on one side,, Quote Share this post Link to post Share on other sites
markymarkthree 160 Posted May 20, 2016 Hello peeps I remember this from years ago, my car leans to the drivers side when looked at front the rear. I did swap the springs round to see if that helped ,nope! Still does it .So I have a few plans Fit one estate rear spring on the drivers side Fit gas assisted shocks Fit one of those rubber spring assisters Anyone solved this on there own car ? Not trying to be funny, but are we talking front end or rear end, red bit. :headscratch: Quote Share this post Link to post Share on other sites
TIB3300 389 Posted May 20, 2016 (edited) Its from the rear I notice it :thumbup: I hear what your saying Steve about the suspension bushes being tightened up while the car had no weight on the wheels. But the car seams to have done this before I rebuilt all the rear end, and yes this was one of the things I advised Pete on with his car after the rebuild. Edited May 20, 2016 by TIB3300 Quote Share this post Link to post Share on other sites
TIB3300 389 Posted May 20, 2016 P/S I am still on the original springs Quote Share this post Link to post Share on other sites
the-ford-cortina.com 225 Posted May 20, 2016 I thought you meant from the front when you were sat in it .... Quote Share this post Link to post Share on other sites
CorKtina 17 Posted May 20, 2016 I thought you meant from the front when you were sat in it .... funnily enough I thought the same Quote Share this post Link to post Share on other sites
nmonkey220 23 Posted May 20, 2016 There has most likely been some balast sat on the drivers side a fair while what orientation are the front subrame bushes in as one of them is off center Quote Share this post Link to post Share on other sites
the-ford-cortina.com 225 Posted May 20, 2016 funnily enough I thought the same Your just not taking this seriously Quote Share this post Link to post Share on other sites
CorKtina 17 Posted May 20, 2016 at least we know who ate all the pies Quote Share this post Link to post Share on other sites
tizwass 23 Posted May 20, 2016 get somebody fat to sit on the other side :thumbup: Quote Share this post Link to post Share on other sites
dgo 66 Posted May 20, 2016 get somebody fat to sit on the other side :thumbup: Haha I like that. Seriously though check all the suspension bushes front and rear if you haven't done so already Quote Share this post Link to post Share on other sites
nmonkey220 23 Posted May 20, 2016 get somebody fat to sit on the other side :thumbup: Or get out Tony :sofa: Quote Share this post Link to post Share on other sites
fatboy 0 Posted May 20, 2016 I had this problem and was easily cured by purchasing some bathroom scales and a diet book... ;) Quote Share this post Link to post Share on other sites
the-ford-cortina.com 225 Posted May 20, 2016 I had this problem and was easily cured by purchasing some bathroom scales and a diet book... ;) were they heavy enough to use as counter balance? Quote Share this post Link to post Share on other sites
