mk4ste 43 Posted May 20, 2016 Hello peeps I remember this from years ago, my car leans to the drivers side when looked at front the rear. I did swap the springs round to see if that helped ,nope! Still does it .So I have a few plans Fit one estate rear spring on the drivers side Fit gas assisted shocks Fit one of those rubber spring assisters Anyone solved this on there own car ? I have had this problem Tony, i tried all the things you mention none worked it turned out to be a bent subframe, we changed it and car now sits perfect. Share this post Link to post Share on other sites
martog 149 Posted May 20, 2016 I have had this problem Tony, i tried all the things you mention none worked it turned out to be a bent subframe, we changed it and car now sits perfect. Don't i know it!!! :headscratch: :tazz: :rant: :wacko: :gun: :lol: :beer: Share this post Link to post Share on other sites
mk4ste 43 Posted May 20, 2016 Don't i know it!!! :headscratch: :tazz: :rant: :wacko: :gun: :lol: :beer: :rofl: :rofl: Share this post Link to post Share on other sites
markymarkthree 178 Posted May 21, 2016 You could try one of these. CLICK ME PLEASE Also I have one new gen Ford spring or a pair of very low millage -1" springs. Both of which I can take to the Yat. Have you also considered moving your handbag to the passenger side. :juggle: Share this post Link to post Share on other sites
TIB3300 455 Posted May 23, 2016 There has most likely been some balast sat on the drivers side a fair while what orientation are the front subrame bushes in as one of them is off center Sorry Andy please explain :headscratch: Share this post Link to post Share on other sites
TIB3300 455 Posted May 23, 2016 (edited) get somebody fat to sit on the other side :thumbup: Or get out Tony :sofa: I had this problem and was easily cured by purchasing some bathroom scales and a diet book... ;) were they heavy enough to use as counter balance? I must thank you all, for your input Edited May 23, 2016 by TIB3300 Share this post Link to post Share on other sites
TIB3300 455 Posted May 23, 2016 I have had this problem Tony, i tried all the things you mention none worked it turned out to be a bent subframe, we changed it and car now sits perfect. I cant see Any damage to either the chassis or the cross member ? Share this post Link to post Share on other sites
TIB3300 455 Posted May 23, 2016 You could try one of these. CLICK ME PLEASE Also I have one new gen Ford spring or a pair of very low millage -1" springs. Both of which I can take to the Yat. Have you also considered moving your handbag to the passenger side. :juggle: Thank you I will try the hand bag part first :glare: Share this post Link to post Share on other sites
the-ford-cortina.com 226 Posted May 23, 2016 I must thank you all, for your input No need to thank me , it was a pleasure Share this post Link to post Share on other sites
Beowulf 87 Posted May 23, 2016 (edited) I must thank you all, for your input Love the emoticon Tibbsy, made me laugh! Edited May 23, 2016 by Beowulf Share this post Link to post Share on other sites
Captain Scarlet 96 Posted May 23, 2016 what orientation are the front subrame bushes in as one of them is off center Yep,i found driver side upper on mine had rotated and contributed to it being lower one side. Share this post Link to post Share on other sites
littlenewt2067 33 Posted May 23, 2016 The subframe bushes are off set tony and they have a tab that comes out at a right angle and goes into a hole in the chassis, that is what Andy was referring to :thumbup: Share this post Link to post Share on other sites
fatboy 0 Posted May 23, 2016 Wedged em in the spring coils.... Share this post Link to post Share on other sites
martog 149 Posted May 24, 2016 I cant see Any damage to either the chassis or the cross member ? I think if you have a bent frame it will be a struggle to bolt it to the car. Ste's was. Must admit in all my years of messing with them this was the first one i've seen. Funnily enough a customer was in at the time and he said he's changed a few due to kerb damage. They must have been fairly rammed up kerbs to bend 'em like that. Share this post Link to post Share on other sites
TIB3300 455 Posted May 25, 2016 nmonkey220, on 20 May 2016 - 01:40 PM, said: what orientation are the front subrame bushes in as one of them is off center Yep,i found driver side upper on mine had rotated and contributed to it being lower one side. The subframe bushes are off set tony and they have a tab that comes out at a right angle and goes into a hole in the chassis, that is what Andy was referring to :thumbup: Thanks Guys I will take a look :showoff: Share this post Link to post Share on other sites
