sheffieldcortinacentre 610 Posted June 26, 2016 So pol one Will read with what amount of cols & how is it adjusted? Would like one to work with v8 if it only needs a tweak. Quote Share this post Link to post Share on other sites
Danish 294 Posted June 26, 2016 I don't know yet, but I will in a few days :thumbup: Quote Share this post Link to post Share on other sites
Pete-H 66 Posted July 14, 2016 MM3 loaned me a PFL one today and yes, it has a 4k7 pot on the circuit board. So it might be that our new circuit will only be needed for facelift gauges, or PFL ones with broken circuit. We're building a prototype at the moment, once that's working we'll be looking to get a batch of circuit boards made up. But, it's not obvious at the moment how to make these available as the board will need calibrating to the engine and gauge - the prototype needs a special USB cable and software to programme a calibration value from a PC or Mac. Maybe we can add '+' and '-' buttons onto the board or something... watch this space. Any news? I know your busy. Quote Share this post Link to post Share on other sites
Danish 294 Posted July 15, 2016 Any news? I know your busy. No, my friend is moving house at the moment, so a bit busy. Quote Share this post Link to post Share on other sites
Pete-H 66 Posted July 15, 2016 ok Np I wish them well with the move always a stressful thing to do. Quote Share this post Link to post Share on other sites
Pete-H 66 Posted August 29, 2016 As Before Any news? Quote Share this post Link to post Share on other sites
Danish 294 Posted August 29, 2016 As Before Any news? She completed the house sale on Friday. Quote Share this post Link to post Share on other sites
Pete-H 66 Posted August 30, 2016 ok great now the hard bit the move. Thank you. Quote Share this post Link to post Share on other sites
Danish 294 Posted August 30, 2016 (edited) ok great now the hard bit the move. Yup. The room I've come to think of as my Pinto workshop is now full of a house-full of furniture. But there is some progress - Heather has the microprocessor up and running - using dummy input and outputs. The next step is driving an actual gauge. We've expanded the project to drive fuel gauge and oil pressure gauges as well as the tacho - the chip can drive up to about 6 gauges. Edited August 30, 2016 by Danish Quote Share this post Link to post Share on other sites
Muzza 1 Posted November 4, 2016 I had the same issue in my Mk2 Cortina. I installed a Bosch distributor that has the BIM module on the side. The BIM varies dwell from 8 deg at idle and up to 28 deg at 6000 rpm The RVI type tacho will not work with a narrow dwell angle. The solution is to replace the RVI electronics with a pulse interface circuit. The new circuit would drive the tacho movement, so externally, the tacho looks original. I designed my own circuit and made a few circuit boards (board is 25x50mm). Gutted the original tacho electronics and installed my own board. Mine is an analogue circuit and has a 20 turn trim pot for fine calibration. I set up the mod'ed tacho alongside my automotive multimeter that has tacho function. I do the initial setup using a sig gen but it is just as easy to do it on a running engine. I do the final checks on a running engine anyway. Works well and have done a whole bunch of others since doing mine. Only problem (for you) is that I am in Australia Quote Share this post Link to post Share on other sites
Danish 294 Posted August 15, 2017 Any news? Pete, my friend has too much on to progress it herself so I'm going to do it myself. I'm going to use an Arduino to drive the tacho needle directly. For my car I'm using the canbus (OBD) data from the engine management - it constantly streams out the engine rpm. If you're still wanting one I think we can build a circuit to count the coil pulses then drive the tacho in the same way. Quote Share this post Link to post Share on other sites
Pete-H 66 Posted August 15, 2017 Ah go on then if you don't mind? Not in as bigger a rush as I cannot do anything with it until the car is back together. Quote Share this post Link to post Share on other sites
Danish 294 Posted August 15, 2017 Ah go on then if you don't mind? No problem. I'm not going into production or anything, but there are a couple of regulars who were interested in the project - and the boards aren't expensive. Quote Share this post Link to post Share on other sites
Pete-H 66 Posted August 15, 2017 No problem. I'm not going into production or anything, but there are a couple of regulars who were interested in the project - and the boards aren't expensive. Quote Share this post Link to post Share on other sites
