cortina-city
Important WARNING XL/GXL/2000E.....
I wonder if it’s worth trying to squirt some ‘switch cleaner lubricant’ into the relay to slow down any corrosion.
If you're careful you can open them up for cleaning. Being a tad obsessive, as well as cleaning the contacts I sent the tin cover away for zinc plating. :)
Must be worth doing Jane,i will probably get around to that in another two years :rolleyes:
Or i may just drill a small hole and squirt some stuff in.
It certainly wouldn't hurt it, but I imagine flooding it with WD40, 40 years down the line from its build date, is a bit like shutting the door after the horse has bolted.
