fatboy
Bottom End Vibration
Had a slight rumble on my bottom end and engine was at about 75% power,
so decided to strip the bottom end and see what might be causing it.
Has anyone got any Araldite I can borrow?
Edited by fatboy
Wonderful what 11,000 rpm will do to a Kent bottom end.
I can see your problem there - there was a piston missing
There's only 3 big end journals so perhaps it's a 3 cylinder Kent?
Wow amazing it ran at all. How did you do that?
He did a similar thing to the engine in his XJ6 back in the early eighties, that came my way to fix too!
The 2.8 was famous for letting go not my fault, ask Blair...
Would you trust his answer.. Probably have weapons of mass destruction inside the sump?
Looks from the photos above as if you're too late....
The truth will come out in 7 years.....
Oh you've been conned too - the truth??
I reckon we all have.
knel how do you do that to a crank? Ive knocked one or two out, but never seen that :shocking:
