Mk3 Mahem 6 Posted September 19, 2016 Hi all, i looked but couldn't find an earlier answer to this.... Does a 205 unleaded head fit onto a 202 block as in the bits line up waterways etc.. or is it too different? Share this post Link to post Share on other sites
mk4ste 43 Posted September 19, 2016 Hi all, i looked but couldn't find an earlier answer to this.... Does a 205 unleaded head fit onto a 202 block as in the bits line up waterways etc.. or is it too different? it should be reet :thumbup: Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted September 19, 2016 Yes Share this post Link to post Share on other sites
stevewes 16 Posted September 19, 2016 (edited) Hi all, i looked but couldn't find an earlier answer to this.... Does a 205 unleaded head fit onto a 202 block as in the bits line up waterways etc.. or is it too different? It will certainly fit no problem, but the only thing you have to watch out for is if it's an unleaded head then these often (but not always) come off a fuel injected car and have slightly elongated (egg shaped) inlet ports. If you're fitting a carb manifold then the width of the contact area between the manifold and head can end up being very thin around the elongated part and therefore very prone to air leaks. I think this is more of an issue with some manifolds than others and I'm afraid I'm not up on the finer details but it's something to be aware of and make sure you use a good quality gasket to reduce the chance of having problems. Edited September 19, 2016 by stevewes Share this post Link to post Share on other sites
Pete-H 69 Posted September 19, 2016 It will certainly fit no problem, but the only thing you have to watch out for is if it's an unleaded head then these often (but not always) come off a fuel injected car and have slightly elongated (egg shaped) inlet ports. If you're fitting a carb manifold then the width of the contact area between the manifold and head can end up being very thin around the elongated part and therefore very prone to air leaks. I think this is more of an issue with some manifolds than others and I'm afraid I'm not up on the finer details but it's something to be aware of and make sure you use a good quality gasket to reduce the chance of having problems. As Steve says there can present a problem but if you were to apply some wellseal liquid gasket to both mating surfaces before you fit the manifold and gasket you should not experience any chance air leaks. Share this post Link to post Share on other sites
Danish 294 Posted September 20, 2016 If you're fitting a carb manifold then the width of the contact area between the manifold and head can end up being very thin around the elongated part and therefore very prone to air leaks. I had this problem. I bought a gasket similar to this: http://rover.ebay.com/rover/1/710-53481-19255-0/1?ff3=4&pub=5574629005&toolid=10001&campid=5335900709&customid=&mpre=http://www.ebay.co.uk/itm/231503145022 Share this post Link to post Share on other sites
