Woodley cortinaman
Mk2 door rubber
Hi all, my n/s/r I has rusted through so if a ages to get a replacement which I've prepped and sprayed in the correct colour, Anchor Blue. Anyway, the old door seal was rotten, so I purchased a complete set of 4 door seals. Unfortunately the seals didn't come with clips to fit the seal to the door. So, I've brought some seal clips that fit the holes in the door. I've found the door seals from a Mondeo fits perfectly. Then, I drilled holes in the correct places and used a tube of 'work'. It's a sealant and a adhesive too. It's clear which helps. I filled the drilled holes with the 'Worx' and then pushed the clips into the holes. I let the suff dry for a few days and now I've fitted door seal and the clips have stayed put. I'm going to try and fit the door the weekend. Happy days :rolleyes: :rolleyes:
Edited by Woodley cortinaman
