The Big 'Un 8 Posted January 11, 2017 Hi, im struggling to get this bolt removed from the rear spring hanger, I've loosened the nut and given it a good hit with a hammer but it wont budge, has anyone got any tips, cheers Steve Quote Share this post Link to post Share on other sites
the-ford-cortina.com 226 Posted January 11, 2017 Hi, im struggling to get this bolt removed from the rear spring hanger, I've loosened the nut and given it a good hit with a hammer but it wont budge, has anyone got any tips, cheers Steve sometimes you just have to cut through them Quote Share this post Link to post Share on other sites
Lotuscops 80 Posted January 11, 2017 It must be rust on the head where it meets the chassis rail as the bush is pure rubber with no metal insert as far as I recall so it won't rust along the shaft - a bit of heat might help or plusgas. If you've drilled out the spot welds are you intending on replacing that rail anyway ? :headscratch: Quote Share this post Link to post Share on other sites
The Big 'Un 8 Posted January 11, 2017 sometimes you just have to cut through them Thanks again That's what I was thinking, would it be worth grinding the flat non nut end off first and see if I can hammer it through? Quote Share this post Link to post Share on other sites
mk2sav 44 Posted January 11, 2017 Just in case - you have undone the nut at the bottom as well ? Quote Share this post Link to post Share on other sites
LHD16E 9 Posted January 11, 2017 swinging shackles are in two half's so both nuts off plenty of wd40 large pry bar and get them apart and it should come out as said its only in rubber Quote Share this post Link to post Share on other sites
rubberhead 4 Posted January 19, 2017 (edited) i think the bolt is welded to the shackle itself,both {bolts} are fixed to shackles one to the top and one to the bottom.you cant remove them unless both nuts and washers are removed first Edited January 19, 2017 by rubberhead Quote Share this post Link to post Share on other sites
