SirRobin
Clutch for 1500GT?
Hello
Just wondering what the current thinking for a Clutch on a 1500GT+ engine putting out about 100BHP
Do I hunt for an old 123E type or use a more modern crossflow type withh a spacer on the thrust bearing?
Thanks
Terry
Go for the later diaphragm clutch as they are a lot better. The original ones were OK for the 78BHP on the original engines but people I have known using them on higher specs than yours have had problems and changed later.
Thanks for the reply. So what do I order, basically what car would it be for? Mk2 Cortina?
Thanks
Sorry to be stupid, but is this the one I need? with a release bearing extension?
My link to Ebay
Edited by SirRobin
thanks for that, but isn't a MK 1 Escort a 165mm clutch?
I thought I needed a 190mm?
Thanks
Terry
that pic is the type of pressure plate with the rounded thrush bearing that you need that pic from burton is for the 1.1 1.3 so yes you are right
mark
Thanks so , I would like to get a new old stock one so I am basically after a 1300 mk 1 escort Clutch with a rounded release bearing and an adapter from Burton?
Thanks
Terry
Thanks
Terry
http://www.burtonpower.com/clutch-cover-7-5-flat-fingers-190mm-fp260c.html
this is the correct pressure plate & you must use spacer with it from burton
Neil at 105speed can sell you the clutch cover, bearing and plate and including spacer. 01234 826827
Edited by kenbex522
