cortina-city 141 Posted January 31, 2017 thanks Mark Gareth SORRY im messin up Gareths thread here, just realised, SORRY! Mark thanks will advise. gotta send steve taylor the pennies first, then it can be collected. Share this post Link to post Share on other sites
Gareth62 18 Posted January 31, 2017 Yes Pete used Hammerite smooth Share this post Link to post Share on other sites
cortina-city 141 Posted February 17, 2017 Gareth where do you buy the mounting bushes for the rack, got my power rack here and a t least one mount is different Share this post Link to post Share on other sites
Gareth62 18 Posted February 17, 2017 (edited) Mine never had bushes it bolted direct to the clip, but I was told that on some racks the driver side bolts down to the clip and the larger rubber from the driver side on a standard rack fits the passenger side so don't know if thats true or not.... You sure you have a Cortina rack? Edited February 17, 2017 by Gareth62 Share this post Link to post Share on other sites
stevewes 16 Posted February 17, 2017 Mine never had bushes it bolted direct to the clip, but I was told that on some racks the driver side bolts down to the clip and the larger rubber from the driver side on a standard rack fits the passenger side so don't know if thats true or not.... You sure you have a Cortina rack? Yep, that's how mine fitted, O/S manual clamp & bush to N/S PAS rack, and O/S PAS rack bolts direct to clip. Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted February 18, 2017 Yes the late mk5 pas rack has a bush to mount it. Share this post Link to post Share on other sites
cortina-city 141 Posted February 18, 2017 (edited) thanks craig , theres a dimple on the underside of mounting area as though its designed to fit and seat into a rubber mount OR its designed to go into a recess in the clip.. the pulley on crank has 86 code. the rack aligns with clip holes ok, its just the aluminium steering box part has dimple, so it wont sit flush on clip. perhaps it requires the rubber bush o sit on. tried looking for one on ebay. no luck. cant see em on flo flex or polybush sight or oldparts store sierra maybe? Edited February 18, 2017 by cortina-city Share this post Link to post Share on other sites
do it sideways 41 Posted February 18, 2017 The cradle has a hole in it that the rack locates into and bolts down. Mk5 rack, mk3 cradle, you need to drill the location hole Simple, Share this post Link to post Share on other sites
cortina-city 141 Posted February 18, 2017 (edited) The cradle has a hole in it that the rack locates into and bolts down. Mk5 rack, mk3 cradle, you need to drill the location hole Simple, thanks steve Edited February 18, 2017 by cortina-city Share this post Link to post Share on other sites
do it sideways 41 Posted February 18, 2017 Don't forget the granada steering coupling Pete Share this post Link to post Share on other sites
cortina-city 141 Posted February 18, 2017 Don't forget the granada steering coupling Pete im on it ste. found mk3 in breakers yard. annoying thing is I broke a mk3 few months ago and didn't keep the linkage Share this post Link to post Share on other sites
cortina-city 141 Posted February 18, 2017 ste I take it that you sill use a rubber bush on passenger side of rack /? seems odd though that they only put one rubber mount bush on it. wonder if the dimple is to stop the rack shifting left right. Share this post Link to post Share on other sites
do it sideways 41 Posted February 18, 2017 Yes the rack is bolted solid where the dimple is and rubber bush the other end, Share this post Link to post Share on other sites
wolfrace 116 Posted February 18, 2017 Can PAS pump be fitted O/S or N/S or does it fit O/S only? Share this post Link to post Share on other sites
cortina-city 141 Posted February 18, 2017 Can PAS pump be fitted O/S or N/S or does it fit O/S only? good question. it looks like the bracket is going to dictate this Richard. I think bracket fits on alternator side and is handed. I will know more when I progress pete or Im sure others will contribute before me here! Share this post Link to post Share on other sites
