Gareth62
Mk3 Power steering upgrade
Steve
will I have to be careful throwing this car thru corners with power steering?
I driven cortinas since late 80s and im used to chucking em about, especially swampy who gets a right hammering in the lakes, cross country etc, swampy is pretty much on rails and you can just slip the rear end out when you need to in the wet etc and ive sort of learned that car.
with power steering, how will I find handling on the new ruby machine?
ruby will have spax and standard at rear with 1" lower front springs
just wondered if its a whole new learning curve with PAS on a Cortina.
all my 10+ cortinas ive owned have all been manual steer
I wouldn't mind PAS in the future, I will have a turbo sat on that side so not sure if it's achievable. Would prefer to bolt it on rather than make mounts etc.
Power steering won't affect the handling as such, it's basically about low speed maneuverability, cortina power racks, for me are over powered, which is why I use the Sierra rack, you get more feel,,,, oh and pintos had power steering pumps on exhaust side, except cosworth,
Good point. Could you use a cossie pump and remote reservoir with a pinto block (I also have a 205)? I guess you prob mentioned it before, if so sorry, but what is involved fitting a sierra rack? I have to rebuild a clip at some point as the one on mine is no good. I have that though but feel I'd be better putting PAS on it while it's out of the car.
I have Granada power steering rack and kit on my mk5 fitted by steve (do it sideways)
Edited by tizwass
Thanks for uploading the pics for everyone and nice job but tbh I'd be well out of my comfort zone with that Steve. I'm much better off just bolting stuff on until I learn how to weld. I've since seen a post rgd the cossy pump and that it fouls the arb so that looks like a no go. Maybe an electric pump hooked to a cortina or granada rack instead might work.
I know some moderns cars have what is called 'hydro-electric' power steering which I assume means a hydraulic pump driven off an electric motor rather than driven off the engine. My own modern (Mondeo) apparently has this, but I've never ventured beyond the sea of plastic covers when I open the bonnet.
Not it you use the smaller pully,
I'm with you there, every time i've fitted it to pintos i ended up taking it off due to bing over light (ok in the V6 due to the extra weight on the front wheel i spose ?), the best i've felt was your sierra rack conversions, just right in weight and feel thumbsup.gif
Do you recon you could vairy the assistance by fitting a valve or such so it was heavyer at low speed headscratch.gif
I've done it rob, pressure sensor from a focus,,
On ohc it's handed to fit on drvs side & combines the mount for alternator.
ive also heard its too light for the 2.0 Cortina. Chirst what have I done. too far in now.if it goes on, I aint taking it off, not after paying for it, stripping it, repainting it and everything.
oh well.
:shocking:
oh well.
:shocking:
Well I like it and have absolutely no regrets about doing it. Wouldn't want to go back to the old set-up now - then again I've got Laser alloys which use the standard tyre size but sit a bit further out which I think weights up the steering a bit.
steve, on swampy I find the standard steering fine, on 175s, on my green GXL it has 185s and I find it heavy, so, ill fit 185s on ruby and this way ill take advantage of the PAS
Please sign in to comment
Sign In Now
