pancakedan 0 Posted February 14, 2017 Does anyone know how Ford restricted BHP on the MK3 1300 economy tuned xflow that was used from Feb 76? Cheers Quote Share this post Link to post Share on other sites
bortaf 96 Posted February 14, 2017 Looking at the manual all i can see is differant dizzy and carb settings, differant jets and accelorator pump strokes, the only other listed differance is the engine code ? Quote Share this post Link to post Share on other sites
pancakedan 0 Posted February 14, 2017 So swapping out the carb should remove the restriction and take it back to the standard tuned 1300? Quote Share this post Link to post Share on other sites
stevewes 16 Posted February 14, 2017 Looking at the manual all i can see is differant dizzy and carb settings, differant jets and accelorator pump strokes, the only other listed differance is the engine code ? If the engine code is different then surely there must be more to it than just carb / dizzy? Maybe different cam profiles on the camshaft, or different compression ratio? Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 767 Posted February 14, 2017 The code refered to the state of tune, as said to best of my knowledge it was carb & dizzy related. Quote Share this post Link to post Share on other sites
pancakedan 0 Posted February 14, 2017 Would a Weber 34 ICH be a straight swap for the 1300 Xflow? Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 767 Posted February 14, 2017 That's the single choke one if memory serves. Then yes. Quote Share this post Link to post Share on other sites
pancakedan 0 Posted February 14, 2017 That's the single choke one if memory serves. Then yes. Thanks Quote Share this post Link to post Share on other sites
wolfrace 116 Posted February 15, 2017 I always thought the HC logo on the xflow was for high compression? Or did it mean something else? Quote Share this post Link to post Share on other sites
teletubby 7 Posted February 15, 2017 If you don't want the original carb after swapping for the Weber I'll buy it Quote Share this post Link to post Share on other sites
pancakedan 0 Posted February 15, 2017 If you don't want the original carb after swapping for the Weber I'll buy it I'll keep you in mind, not sure when I'll be doing though. Quote Share this post Link to post Share on other sites
rubberhead 4 Posted February 15, 2017 i had one of these in the 80s,i replaced carb with a twin choke from a 1300e.ran almost as good as a 1600 ohv. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 767 Posted February 15, 2017 Yes hc means high compressìon, but the eng codes refer to more than compression ratio. Also after all these years the rocker cover or just the sticker may have Been replaced. A mk5 high compression engine with a vv carb as the eng code "LC" for example. Quote Share this post Link to post Share on other sites
wolfrace 116 Posted February 15, 2017 (edited) Yhea but would the high compression be to do with the head/pistons or block or does the head gasket increase this as I'm guessing they wouldn't say high compression if they'd just tweeked the carb and timing? Edited February 15, 2017 by wolfrace Quote Share this post Link to post Share on other sites
pancakedan 0 Posted February 15, 2017 i had one of these in the 80s,i replaced carb with a twin choke from a 1300e.ran almost as good as a 1600 ohv. Interesting! Think I'll have to do this at some point but prob go with the single choke. Quote Share this post Link to post Share on other sites
