Scrumpy
MK2 oil pickup pipe removal
Hi all,
Im swapping the sumps on one of my old mk2 1600 xflows as its going into a friends car and needs a rear bowl sump fitting, however Im failing miserably at removing the original oil pick up pipe. Im sure Ive removed them before and a couple of twists with a set of molegrips sets them on their way, but I cant get this one to budge and Im just crushing the pipe.
Any top tips?
I use a bit of steel rod that is a close fit inside the tube, then use some curved jaw grips. Sometimes leaves a few marks but the rod inside the tube stops it crushing.
Cheers, I'll give that a go.
I found a chunky crosshead screwdriver that was a perfect fit and tried again with that down the tube. Tube came straight out!
Top tip, thankyou :thumbup: :thumbup: :thumbup:
good tip thanks - we often have the same problem as Scrumpy
