Cortinamark5
Anyone refurbed a Koln axle?
Hi, been told my diff or axle bearings need replacing as its had a whining/graunch noise since I bought it last year, has anyone had a refurb done and what sort of cost could I expect from a garage/specialist?. DON'T REALLY WANT TO GO DOWN SECOND HAND ROUTE AS I WOULD NOT KNOW IF I WAS BUYING ANOTHER BAD ONE. Thanks in advance :)
Are you sure it's the diff or could the noise be wheel bearings? Also have you checked the oil type and level?
Several hundred pounds, you'll get a used one for £75ish
Not much to check check for excess play by turning it, whip cover off & look for physical damage.
I haven't done a Kolner,but I have stepped into the world of doing a front diff from a Sierra. I know it's mot the same,but the makeup is. In fact some of the roller bearings in a Kolner were carried over to the Sierra. I have the part numbers on Cortina Microfiche,but Fordopedia don't
Hi, I'm new user in this blog.
I own a Cortina from 1977 and I will use it as a donor car for a Seven replica.
I'm looking for a shoerter diff. May be mine it's a 3,54 and think could be better a 4,11
It's possible to buy one of this kind. I have a very good friend living at Chicester and he can do the job for me and send it to Montevideo, Uruguay
Thanks a lot
You need a 1.6 auto axle also fitted to the 1.6 wagon or the 4.44 fitted to the 1.3 saloon.
Both of these are koln axle (parts aren't interchangeable with your atlas axle).
Due to the light weight of a seven you shouldn't have any problems with a powerful engine.
