jdodds
Cortina mk4 inner wing
Hi quick question will a mk3 inner wing fit a mk4 without too much alteration. Thanks
A facelift mk3 will fit the mk4 ,there are minor differences to the pressings on inner wing & the bumper mounting holes.
The pre facelift mk3 (with smaller cradle mounting rubbers) is different as is the MK5.
They all have the same mounting dimensions & same outer profile to the bulkhead & wing mounting rail.
Couldve sworn there was another post in here?
Looking for similar info but other way round will mk4/5 inner wing (upper inner only not leg ) fit pre face lift mk3?
thanks
More or less,  Mk5 has a rectangular hole for indicator mount & a dip for the bigger diameter servo so the rivet counters will be able to tell.
So MK4 is closer.
